Wanted...97 VW Jetta CD changer Pin outs
  • Wanted...97 VW Jetta CD changer Pin outs
    I looked around here and on vortex and have been unable to find a diagram of the pinouts for my cd changer connector (it is the round one not the square one) I wanted to tap into this so I could avoid the losses with tape adaptors and fm modulators. I would do it like I normally do...cut all the wires and start trying all combinations, but 81 possibilities and the likelhood of be blowing something up I thought I would ask first. Any help would be appriciated. Thanks in advance.
    1997 VW Jetta GLX VR6
    old HP MP
    PIII 600 or so 256 MB
    7" Xenarc
    and some plywood holding it all together
    My Project
    If you post a photo of that connector it would help. I think it is a DIN8 connector right ?
    Car pc integration with ease
    Car mediacenter
      here is the connector it has 13 pins on it arranged in three rows of 4 and one single pin. The CD changer is VCD-550. I thought I had found a diagram, but it was the same connector different year so different pinouts.
      Also, if anyone has a way to test which ones are the audio outs that would help as well.
      old HP MP
      7" Xenarc
      My Project
        I remmeber seeing some site that had links to info on all types of changers, I will have to see if has the info you need when I get home. You could also try the site for all the info on the mk4 changer controls (the one witht he board you can build yourslef, I forget the name).
          Well,
          I never saw a connector like this. I think you should go from the headunit. Here is the info:
          http://www.john-wasser.com/NewBeetle/CDChanger.html
          This also would help.
          http://www.k9spud.com/vwcdpic/devel/audi-pinout.html
          Just match the colors coming out from the HU to the CDC. It should be a snap.
          Car mediacenter
