sub advice needed..
  • sub advice needed..
    hi guys! i am after a sub setup for a shogun sport (challanger). i am going to put a bulkhead behind the back seats and hopefully poke my sub through this with the box behind, firing into the back of the rear seats. i have a jbl 2x75rms or 1x150rms. i would like the bass to sound 'natural' not 'getto bad' and size of the box is an issue. would i be better with 1 sub or 2 smaller in 2 boxes i will use the above amp in either 1 or 2 channel mode to suit. thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    here we go again....
    Jan Bennett
      So I bought a ****(tm) kenwood (yes, i know they make blenders) sub.
      It's rated at 175W rms (not alot) and 700W (max) 4Ohms.... I was looking at a 200W rms alpine amp, http://www.caraudiodirect.co.uk/prod...d2f277e452c0ae
      that should be fine, shouldn't it? So long as I dont wire it backwards (haha scouse) or turn it up all the way?
      I realised that even though I have a medium sized brain I didn't know if it's as simple as matching up the rms values on the amp to the sub at the correct impedance, or whether I'm just a total pleb......
      Cat
      Woot, or something.
      Epia M10000 (less rubbish than the 800) :: LCD touchscreen
      GPS :: 80G drive :: Not enough ram... Never enough..
