Audio Selector?
  • Audio Selector?
    Hi again guys, just got a lil question for ya.
    Ok well i have a sony cdx-f5500 headunit and it has an audio input for the cd changer that you hook up, that i do have hooked up. Ya, anyways, if you don't have the sony cable hooked up to the cd changer, the headunit can't play audio from the audio input cables, simple.
    Anyways i pluged in a cd player to the rca-in cables and left the signal cable in the cd-changer. It played and on the headunit it just showed what track the cd was on, in the cd changer.
    Sorry if all this is hard to understand, i can clear it up for you all if need be.
    My question is, is there a switch/cable/box that you can use to change between audio sources?
    Here is a rough sketch of what it should look like, i know its crap:
    http://pg.photos.yahoo.com/ph/bedpan...4e.jpg&.src=ph
    2009 Altima 2.5S CVT Dark Slate
    Wow, I am sure that makes a lot of sense to someone else, but i am kinda lost, is there any guides out there?
    Or anyway to tell this to a dummy?
    sorry, and thanks for the help.
      Naw, i can make the switch, i just need a little more guidence.
        No More Help?
          Originally posted by ClubFed11
          No More Help?
          Wondering if you could help me in making a switch...
          here's my problem:
          http://www.mp3car.com/vbulletin/show...audio+selector
          Thanks!
            http://www.radioshack.com/product/in...entPage=search
            this?
            Take 2 - '03 Audi A4
            macmini with an 8" widescreen (in progress)
            My 2004 Ford Ranger:
            14" LCD w/ custom made aluminum bezel
            Completly custom computer case
            status: Totaled
              Originally posted by Rocky388
              yeah i've seen those before with a manual switch but i'd like something more automatic.
              it should give preference to line a and when line b turns on it should switch over. and then switch back to line a when line b turns off.
