5.1 info help
  • 5.1 info help
    alright... i did a search and read quite a few threads... still unclear on a few things... first off:
    i have a MII 1.2 board... i'm guessing buying a 5.1 sound card will be much better than trying to use the onboard 5.1. (i don't care for XM)
    second... if i buy a 5.1 sound card.... i need a 5 channel amp correct?
    there's an amp by phoenix gold that supposedly does 5.1 (http://www.infinitecaraudio.com/cgi-...atalogno=R51MT)
    if i get this... will i still need to buy a sound card? And if so... any specific output connections needed?
    last question is more opinion... besides DVD audio and DVD's... would my sound quality better with a 5.1 sound car, or running it through a pioneer HU (basic left and right and sub of course)?
    thanks
    Your typical surround sound sound card will have 3 audio outputs. One is a Front Left/Right, then a Rear Left/Right, then a Center/Subwoofer. You will not need a 5 channel amplifier. I use a 4 channel amplifier, and plug the Front and Rear outputs to connect to it. Then I plug the subwoofer output to the Mono amplifier for the subwoofers.
    Edit:
    To answer the last question. Windows typically plays the rear speakers very quietly. Why it does this, I don't know. But it is more of a home audio setup, rather than a car. It may be more desirable to use a RCA splitter to split the front output to go to front and rear, since that is how headuntis do it.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
      oky got it...
      so windows controls the sound processing? Is that true even i buy a 5.1 sound card? I'd imagine that the sound card would have its own processor that i can control? Please correct me if i'm wrong.
      you're using 2 amps then? A 4 channel for FR FL and RL RR and then another 2 channel for center and SUB?
      Also... if i split the front stage with the rear stage... there wouldn't really be much of a use to go 5.1 right?
      The phoenix gold octane-r 5.1 digital amp supposedlly allows you to tune each channel individually.... i want to use this amp... but am not sure if i will need any additional hardware.
      I'm still trying to figure out how to turn the RCA out into a SPDIF out on my mobo (no manual)
        And you haven't even bothered to look for it, have you?
        http://www.viaembedded.com/product/3...a-mii_v150.pdf
        How about the Wiki?
          oky got it...
          Windows doesn't process it, it just plays the rear speakers fairly quiet, compared to the front speakers. Yes, I use two amplifiers, one is a 4 channel, the input comes from the line out (Green) jack from my computer, and is splitted to go to both front and rear inputs on my amplifier. I simply use the pass thru on my 4-channel amp to go to my subwoofer amp. I used to run the center/subwoofer output to my subwoofer amplifier, but i changed motherboards and do not do that anymore.
          5.1 would not be good for anything if you just split the front to go to the rear aswell.
          If you wire up the 5.1 as if you're in a house, it is going to sound fairly different. You may like it, but chances are you wont.
            haha i actually found it right after i posted cuz i had a feeling someone would say that...
              I believe the 5.1 amp will take the 3 inputs from your sound card and split them accordingly(based on my own research).
              You would only need to have the soundcard and the 5.1 amp
              The amp(phoenix), I believe allows for changing the level of each separate channel.
              Then you would only need Volume control on the PC.
              You should still get a nice stereo sound from the audio card even without 5.1(for CDs, MP3s, etc).
              You could also get a sound processor(I think) that allows you to adjust the levels of each channel. I think that would sit between the soundcard and the amp.... but I really don't know yet.
              EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
              Status:
              Installed & Working....
              Custom enclosures
              Newbie Guide
                I'm pretty please with the onboard audio of the Via Epia, if you get the Viynl Audio drivers.
                Progress [I will seriously never be done!]
                Via EPIA MII
                512MB RAM
                OEM GPS (embedded)
                nLite WinXP pro on
                1GB Extreme III CF card
                Carnetix 1260 startup/ DC-DC regulator
                Software: Still, re-Writing my existing front end in .Net
                  The phoenix amp he's referring to takes SP/DIF iirc.
                    yea... that phoenix amp is the route i wanted to take... however no store seems to have them in stock... in fact i don't think its even produced anymore
                    intella.... you mentioned you're using the onboard 5.1 smart system... does it utilize a lot of CPU resources? I was thinking about doing this.... but then i wouldn't have an input for a FM tuner
                      oh... and do 5.1 PCI sound cards really take up that much resources in the first place?
                        No.
                        What kind of system are you running?
                          Hey IntellaWorks
                          Where can I get ahold of the "Viynl Audio drivers"
                          I can't seem to find them
                          Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
                          Progress [-----------] 0%
                          Who the Daddy Iz!
                            i'm running the EPIA MII 1.2GHz... it supports 5.1 already... i just want to avoid the 1/8" minijacks and having to convert to RCA. That and i wasn't sure if running 5.1 would tax my CPU.
                            Also... has anyone found a way to run a FM tuner when converting the jacks to 5.1?
