removing part of dustcap in speakers
  • removing part of dustcap in speakers
    In our boat we have 4 speakers, 2 in front with grills that stick out and 2 inback with grills that are flat over the edge of the speaker. on the speakers they have the cone shaped things on the dustcap(sorry dont know the name) well when i turn it up loud the "things" hit the grills and make a loud annoying click noise. I was wondering if i could just trim down this part of the speaker so that it wouldn't hit the grill?
    sorry that this is sort of the wrong forum.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
      i know what u talkin bout :-D i removed my subwoofer dustcap (thas what u call it lol) when i accidently hit it with a screwdriver and made a hole in it... but basicly i believe it effects the sound in the music if u remove it but maybe it wont u can try or the other thing u can do is buy bigger grilles or get spacers so when u screw the grille back on u got SPEAKER - SPACER - GRILLE - SCREW spacer as in a washer or something hope it helped ! good luck!
        nope. if you put a hole in the dustcap, the t/s params of the speaker will change, but most importantly less air is drawn through the ventpole to cool the voice coil. itll kill your thermal power handling.
        spacers are the way to go, for sure
          What you are talking about is commonly found on cheaper speakers, it is called a weezer cone. It looks like a inverted cone glued to the center of the speaker and is used to produce the high frequencies. You could trim it but I bet the speakers will sound even worse, try trimming down the grill first.
            i cant exactly trim down the grill i guess i'll just have to see if i can make the sound more to the front speakers
