Wiring 3 amps from a pc sound card!
  • Wiring 3 amps from a pc sound card!
    I will be installing a computer into my car but i wish to have 2 separate amps for 2 subs and a 3rd for the other speakers, is this possible or is there another way which will benifit me, cheers for ne help in advance lee
    Luv A Dub Dub
    www.pestclub.com
    Current progress - Modding a VW Splittie
    That would work, but odds are you would only need 1 amp for the 2 subs, unless you have some massive sub that I have never heard of before.
    You can either split the line to go to all the amps (if your sound card only has L&R outs), or if you have a sound card with x.1 out, then you have no problem. The amp will have the cutoff frequencies so you will not damage your sub.
    Make sure to get a class D amp for your subs, by the way.
    Matt
      You need to post what subs/speakers and amps you have.
      You DO NOT NEED class D on amps. They do make more power but are not a requirement.
        Thanx for your replies guys this has helped me alot, I had an idea of using a 5.1 sound card and I will only use 1 amp now then. cheers again lee
        Luv A Dub Dub
        www.pestclub.com
