Multiple Amp & Distribution Question
  • Multiple Amp & Distribution Question
    In my new car, I am going to be running two amps (not at first) plus the carputer.
    I will be running two Alpine amps: 4 channel amp + sub amp. Both amps require 8 gauge power and ground.
    In trying to hook everything up, I was looking to run 4 gauge power directly from an yellowtop Optima battery into a distribution block (which one?)
    and then from there split it three ways to the amps and pc
    As I said before the amps will be bought in stages, so far now I want to lay the foundation for everything and do it right from the beginning.
    2005 Black Chevy Impala
    http://www.crutchfield.com/S-Rtdhle9...sp?g=715&avf=N
    Renault Megane...the OEM look
      I think this is what I need for two amps and the PC:
      http://www.crutchfield.com/S-WD3ZZyr...15&I=211CBR44A
      Would this work?
        Would this work?
        Why not look on ebay?
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          Would any of thise blocks work? I wasi thinking the other product because it would make grounded the amps and the PC to the same point easy.
            Don't use a block on the ground. You want to use a star ground. Bad grounding methods are the cause of 90% of noise in systems.
              why can't you use a block? ... if I'm not mistaken, connecting all grounds together and then a single cable from that point to the chasis is one form of star grounding ... with this method using a non fused distro block establishes just that.
              I certainly wouldn't recommend using a fused block for ground ... but I don't see any problem with using a non fused block.
              My JeepPC Install
              "there are no stupid questions, just stupid people."
              "it's been agreed the whole world stinks so no one's taking showers anymore"
                Don't waste your money on a fancy distro block. Head down to your local electronics shop (in australia we have something like jaycar.com.au) and grab a 3 or 4 way fused distro block. Just make sure it is 4ag in and 8ag out. Chuck in fuses appropriate to the equipment and you're all set.
                Probably a waste at 80bucks (US!) for something that is just a chunk of metal with some fuse holders and a bit of insulation.
                  I gave the crutchfield link only becuase they have large pics and detailed info about their products. I have a distro block for power, but I don't use one for the ground. I just have them all bolted in one place...
                    If your looking for a cheap way out just get a 3 way 4 gauge block,And yes using a solid block for the ground is a very good idea.
                    2-15" ILO lcd w/DVI
                    6800 gt Duel DVI out
                    p4 1.6ghz flex atx board
                    1gb 400 ram
                    120gb(2-60gb raid) sata hd
                    2-60gb hotswap
                    WIN2K Pro SP2
                    M.A.M.E. w/2,300 games
                    CARPuter info
                      Can you provide some specific links to blocks youd recommend?
                      How about this:
                      Basic 4 Gauge Amp Install Kit ($18.99): http://www.knukonceptz.com/productDe...rodID=KOL-BAK4
                      -and-
                      Three Output AGU Fused Distribution Block ($7.49)
                      http://www.knukonceptz.com/productDe...prodID=FB-3438
                      -with-
                      3 Outputs for: Alpine MRV-F345, Alpine MRD-M301 and PC
                      Can you think of anything else I might need?
                        You'll need a cable(s) to hook up the signal output of the PC to the RCA inputs of the amps. And also speaker wire. Knukonceptz has some decent prices on them as well. I bought all my wire for my system from them. Here's a thread dealing with the signal cable: http://www.mp3car.com/vbulletin/showthread.php?t=48516
                        WORKLOG
                        Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
                        Webpage
                          But do you think that the abovementioned items will work as the foundation for the system?
                            Bump
                              those items will be great. youll always want for more items though, you may run out of ring terminals, you might need spades to get from 8 gauge to your amps, or maye they accept raw wire, youll need a connector to get from 8 gauge to the computer PSU, they never ever ever come with enough zipties to make things clean, etc, etc, etc.
