PAC Audio Aux input amp pop question
  • PAC Audio Aux input amp pop question
    I'm doing an install in a G35 Coupe. I'm using the PAC audio module that gives an extra input instead of the satellite radio feature in the G35.
    My last install was in my own car, a Protege 5. I had a regular amp fed by RCAs from my carpc. The Carnetix power supply turned on the amp after a certain delay to avoid speaker pop when the system boots up.
    I don't see how to avoid speaker pop in this install, since the power supply is no longer in control. Has anybody used the PAC Audio module? Does it have that feature?
