spdif question?
  • spdif question?
    hi guys,
    i have a spdif out on my motherboard's audio and was wondering if you there was a way to connect the spdif cable to my aux-rca in on my headunit?
    thanks.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    No. You'd need a headunit with SPDIF input.
    How about the Wiki?
      that sucks.. thanks for the reply.
      NANO-ITX+m1-atx
      512 DDRsodimm
      60g SATA Laptop HD
      4x Apple DVDslot
      digimoto OBDii
      mS GPS
      mini BT keyboard
        I tried to find a HU with spdif in, but had no luck, are they out there? What about a small stand alone converter that takes the digital signal and converts it to analog?
        |V1 Virtual Display|
        Hard work often pays off over time, laziness always pays off right now.
          Or why dont you just use the rca(headphone) jack on the mobo? Or does it not have?
            I'm certain that someone would rather use the digital audio out for sound quality.
            There are a couple people here that have done just that and outputted SPDIF to either a head unit or another digital processing unit.
            I'd think that for sound quality, especially if you're going to do 5.1 surround in the car, as well as cable management, SPDIF would be the way to go. The trick is getting all the quipment you need to pull it off.
            How about the Wiki?
              digital should provide a cleaner signal (less interference). The digital to analog conversion would be happening closer to the speakers which should provide higher sound quality, in theory.
              |V1 Virtual Display|
                i have been looking into this option as well. I have found this to be the best hu you can get with a digital in. if you notice it actually has add-on nav on that small screen. i am sure we someone can find a way to ge the nav to work on the auto-pc.
                eclipse w/ digital in
                  Looks like an affordable option
                  DICE Los Angeles
                    yeah, out of my price range, but I didn;t expect something cheap.... oh well
                    |V1 Virtual Display|
                      hmmmmm.....
                      http://sound.westhost.com/project85.htm
                      |V1 Virtual Display|
                        or this...
                        Clarion ProAudio DRZ9255
                        BMW E36 Project [ ========= ]
                        Hardware:
                        Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
                        Software:
                        FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
                          damn, $1200....
                          |V1 Virtual Display|
                            Originally posted by zPilott
                            damn, $1200....
                            I had the same impression...
                            Hardware:
                            Software:
                              I plan to use one of these "Cambridge soundworks desktop theater 5.1" decoder amps in my car.
