BMW fuse Info
  • BMW fuse Info
    Anybody got any? Ive been searching, and i cant find out what fuse to check for my radio. My 12v switched wire has stop responding, i need to see if the fuse is blown. is there a mapping or anyone have experience?
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
      owners manual? normally has what fuse is for what / where they are.
      Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
      PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
      Toys:K8055 relay board, Elmscan OBDII
      Type-R Mini
        i didnt think to check that, was only checking online sources, ill look at that when i get home from work, thanks.
          its not in the manual, i guess no one knows ?
            http://forums.bimmerforums.com/forum/
            PowerVoice v1 | NaviVoice Source
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              Or just try looking on the bottom of the fuse panel cover...
                Or under the hood!!
                My truck has the AMP and audio fuses next to the battery.
                RexBruMet Skin for FrodoPlayer
                Nissan Aux-in MOD
                Originally posted by bgoodman
                We're an international forum, post in whatever langauge you like.
                  Originally posted by thanatos106
                  Or under the hood!!
                  Yeh. I somehow blew a fuse and looked in the manual and couldn't find it there. Turned out that it was one of those fuses in the engine compartment. I didn't even get to read about those, even though they were in my manual
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    in the e46 the fuse is under the hood, i was looking at the many plugs but i dont know which is the one im looking for, and there is no writing anywhere ,not even in my manual!! someoen on the other forum posted the same problem tonite so we will see what happens . . .
                    edit: found fuse box in glove compartment and fixed it !
