Jetta 2004... Wire code... Need help.
  • Jetta 2004... Wire code... Need help.
    I got a Jetta 2004 with the double radio (cassette and cd), i manage to pass a power wire from the battery to the trunk.
    But cannot find a way to "power up" my amp. Is there a wire that could turn on my amp and my capacitor?
    Here what i got : Sony Xplod 1000W, Box with 2 12" Infinity spk, 1 farad Stingpro capacitor. Ans since there is no rca output on my Jetta radio, i also got a small box that convert spk signal to rca connector.
    Thank you for helping...
    REXTHEGREAT
    Since it seems you can't use the or I thought I would be nice today
      That diagram is dated in 1997. It does not apply to 2004 Jetta. I have the same car and the connector looks and works differently. You aren't going to find that "turn on" wire car because it's controlled over CAN-BUS. CAN-Bus also controls the dimmer/illumination wire. Search on vwvotex.com to see where you can tap an accessory wire. You'll find a good point under the steering wheel in a power distribution block.
        You might wish to try vwvortex.com
          So the mk3 and 4 wirring is the same, if your deck is can there is a switched wire above where your deadpedal is right below the relay panel.
            Hope this helps
            2004 Jetta
            Security
            Battery RED + (+) IGNITION SWITCH HARNESS
            Ignition GRN (+) IGNITION SWITCH HARNESS
            Starter01 BLK/YEL + (+) IGNITION SWITCH HARNESS
            AllDoorTrigger BRN/VIO (-) (-) DRIVER'S KICK PANEL AT DOME DELAY RELAY
            TrunkTrigger BRN/BLK (-) (-) AT TRUNK LIGHT
            HoodTrigger N/A
            FactoryAlarmDisarm N/A
            ParkingLights GRY/YEL L (+) GRY/WHT R AT LIGHT SWITCH
            Security
            Parking Lights
            ALSO (+) GRAY/WHITE-DIODE ISOLATE
            Remote Start
            Ignition02 + IGNITION SWITCH HARNESS
            Ignition03 +
            Accessory01 VIO + (+) IGNITION SWITCH HARNESS
            Accessory02 +
            AntiTheftSystemNONE
            Tach BLK (-) (-) AT DIAGNOSTIC CONNECTOR
            SpeedSense BRN/RED (AC) REAR AXLE
            BrakeLights GRN/RED (+) AT BRAKE SWITCH
            ReverseLights BLU/WHT (+) AT REVERSE LIGHT SWITCH
            Horn BRN/YEL (-) AT STEERING COLUMN
            Doorlocks / Window
            PowerUnLock GRN/BLU (-) (-) NEGATIVE TRIGGER
            PowerLock YEL/BLU (-) (-) DRIVER'S KICK SPK "KEEP RELAYS UPRIGHT"
            Convenience
            HeadLights YEL/GRN (-) AT LIGHT SWITCH
            LowSpeedWipers BLK/RED (-) (-) AT WIPER SWITCH
            Mobile Audio / Video
            Ground BRN - (-) RADIO HARNESS
            PowerAntenna WHT (+) RADIO HARNESS
            FrontLeftSpeakerPos WHT
            FrontLeftSpeakerNeg BLK
            FrontRightSpeakerPos WHT
            FrontRightSpeakerNeg BLACK
            RearLeftSpeakerPos WHT
            RearLeftSpeakerNeg BLK
            RearRightSpeakerPos WHT
            RearRightSpeakerNeg BLK
            Amp BEHIND REAR SEAT
            Control Modules
            Aura MR62 (F and R)
            My Current MP3s
            IamDefiler.com
              that would be a negative...
                a negative to what?
                  hey, fyi theres no switched power behind your head unit, get a voltmeter and test the fuses on the side of your car, between the door and the dash (drivers side) for a switched power, thats how i wired mine
