ME2 Equalizer support?
  • ME2 Equalizer support?
    I have just joined the forum because i'm planning to do my own carputer and realised that ME is the perfect solution for me.
    The only thing that bothers me is the lack of EQ in the ME.
    Developer: I know that your hand are allready full with implementing many neat stuff in the newest versions, but maybe you could take a look a ClAMP.
    I think clamp should be the easiest way of implementing EQ into ME because clamp is commandline driven. I'm not a professional software developer but i think that the only thing to do here is graphic tabs, which then control then winamp over clamp. The readings to ME should be done over clamp so, when you open EQ in ME it sets the current settings on the tabs. By changing the tabs clamp is being run in background setting the EQ on Winamp.
    Thank you,
    I don't think ME is even being developed anymore..
    I thought iwas replaced by roadrunner or soemthing like that, I'm a Centrafuse guy myself..
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
      Oh, sorry! I'm new to this stuff, so don't take it too hard.
