Carputers and subs??
  • Carputers and subs??
    hello this is my first post.
    i'm looking into the whole carputer thing and just wondered if a sub would cause problems with a computer running in the boot together?
    My install... check it out!
    www.mp3car.com/vbulletin/showthread.php?t=56599
    if by together you mean affixed to one another then yes.
    if by together you mean separated by reasonable distance, vibration and EMF dampening, then no.. no problems at all.
    •Micke
      yeah as in one side of the boot to the other.
      thankyou
        No issues on either EMF or vibration mounted to each other either.... a little searching will show this to be true.
        TruckinMP3
        Read the FAQ!
          I used to have my laptop mounted to the sub box on my last setup no problems.
          1990 Jeep Cherokee
          2000 VW Golf TDI 4dr
          2005 VW GTI MKIV - SOLD
            just did a bit of a search and found that it doesn't seem to pose a problem.
            thankyou guys
              I've had my 2 12" Cerwin Vegas pushed by 600 watts RMS, pounding right infront of my car computer, and it has never caused a problem. The ultimate test will come with I get my new system, 2 Avalanches pushed by 2,500 watts RMS (2 NINe.1 Amps).
                i have my carpc mounted to the side of my sub box (there is a 3 in spacer in there which one of my amps sits in between). But i've had no issues.
                I did replace my HD under warranty a few weeks ago....but that was from vibration i'm guessing. It lasted over a year though and would have kept going if i didn't want to replace it.
                cheers
                Asus Pundit Barebones PC
                7" Lilliput LCD
                P4 2.8ghz 512mb 120gb
                Windows XP Pro, VOICES
                Sony Xplode 10in Sub, Rockford 600w amp
                Pioneer 6x9's and 4x6's, Kenwood 4ch amp
                Black Widow Alarm with Pager
                  excellent. so it looks like that won't be an issue then
                    i have my carpc mounted to my sub box too
                    Signature: [==||========] 20% complete
                      142.~ dB and not a single hicup yet!
                      Jan Bennett
                        Do NOT mount your computer on your box. Avoid it unless there absolutely NO other place you can put it. Subwoofer boxes flex which will cause unwanted stress on your motherboard and other parts.
                          Bad info, Listen to Red.... She does know.
                          TruckinMP3
                          Read the FAQ!
                            eh - I would avoid the sub box if at all possible....but there are instances where I guess it can't be avoided....I guess.....maybe....once in a blue moon...hahahahah
                            and what's with this all of a sudden....seems as if it's sarcasm for everyone as of late....
                            ..."listen to red....she knows" seems to be all over the place around here....
                            that's bad advice...don't just listen to me...I don't know....lol
                            Jan Bennett
                              I've had it on my sub box for over a year, not one issue
                              Like i said a disk did just start to go on me, however that is more likely due to vibrations etc
                              I wouldn't worry about it. I probably woudln't mount my motherboard on my subbox though
                              7" Lilliput LCD
