no sound from speakers
  • no sound from speakers
    now before you say it... I have read all of the FAQs multiple times and checked over my wiring at least 5 times.
    now my carpc works just fine, I have it hooked up into my vehicle and I can hear the sound output when using headphones. but when I plug in the stereo to rca adapter plug for the amp no sound comes out of the speakers. The amp IS turned on, I am sure of this. There is a short period of static coming from the speakers when the amp is first turned on and the power LED is lit up. I cannot figure out what is not working correctly unless the amp itself has not been working from the start.
    Anybody have an idea of why I am not getting any sound from my speakers?
    Well if you checked your wiring 5 times...check the amp at least once.
    My 2000 Accord Project
      what is that supposed to mean?
        are you using a usb sound card?
        2002 Mitsubishi Galant
        Carputer Specs:
        Via M10K
        512mb Ram
        60GB HDD
        Souund Blaster Audigy2 NX
        OPUS ITX PC Case
          m10000 onboard sound, it has to be something with the amp, not the computer because I can hear the music just fine with headphones but nothing once i plug in the amp.
            get different sound card. You mobo SC wont give good sound. Get an external SC. It would be much better!
            Carputer Specs:
            Via M10K
            512mb Ram
            60GB HDD
            OPUS ITX PC Case
              thanks for the advice, but I would like to actually be able to hear the sound from my speakers first!
                are you sure the plugs (adapters) are phono and not mono
                Carputer Specs:
                Via M10K
                512mb Ram
                60GB HDD
                OPUS ITX PC Case
                  was your amp working before?
                  maybe in a previous car stereo setup?
                  maybe you have to set the gain? the voltage signal from the computer isn't very high
                  [||||||||||||||||||||] - final touches
                  SUPER 7" VGA w/ TS
                  Toshiba Satellite 3000
                  P3 850
                  256MB
                  30GB
                  Geforce2 Go
                  DVD
                  Orinoco 802.11b PCMCIA
                  nlite WinXP 350MB installed
                  RoadRunner
                  iGuidance 2.1
                  Holux GM210 GPS
                  Xantrex Xpower 300
                    well I just bought the amp so I have not tested it before but I will try to do that in the next day or two.
                    I adjusted the gain and nothing could be heard from the speakers.
                    I am sure the plugs are phono
