line in epia -> out usb audio?
  • line in epia -> out usb audio?
    I have an EpiaM in the trunk and an XMPCR next to it. The main audio for the system is a USB soundcard in the dash, connected to the stock headunit.
    Is there a way to take the audio from the XMPCR through the line in of the Epia onboard sound, and route it out through the USB soudcard? I have searched around for options, but so far the only thing I found was a shareware utility that would work, but needed to be started and configured each time the machine started up. Any other ideas out there? Thanks.
    Via Epia M-10000 / Morex 3688 / Lilliput 7" / Opus 90W
    Acura TSX / Done!
    you should be able to I havn't ran 2 sound cards in quite sometime(about 3yrs) but can you not unmute the linin one the epia in the sounds and audio devices section of control panel?
      Tried that, several times. No sound out the usb. The closest I got was with the linein plugin in winamp. I could see there was input (spectrum analyzer) but still no sound...
      Acura TSX / Done!
        I know this is an old post, but just in case you never resolved this:
        http://www.mp3car.com/vbulletin/showthread.php?t=55430
