New Turtle Beach card?
  • New Turtle Beach card?
    Has anyone used this card yet? Advantages are that it is really small and only requires USB BUS power - no 5V required like most other external cards
    I can't seem to find any tech specs for it though - like s/n ratio etc. It does have an optical output so maybe this could be hooked up to a nice audiocontrol line driver / EQ and be a very nice carpc solution.
    This could be a really great device for carpcs! Best part: only $30!
    Opinions?
    I actually bought this card for $22 from circuit city. I currently have a SB Audigy hooked up. I'm going to try this and see how it sounds.
    Anyone else care to comment?
      do you have a link to it?
      Jan Bennett
        http://www.turtlebeach.com/site/prod...udioadvantage/
          It's virtual 5.1, which you can simulate with software. The only advantage is that it provides an optical out. So use this if you have a HU that has Opt in.
          iGMon - Integration between iGuidance and Road Runner
          CFX - Skin for Road Runner
            optical is the only way to go IMO.....I wont run it any other way in my car....now if I could only find an optical ONLY sound card that doesn't have a bunch of other crap on it!
            EDIT:
            thank for posting the link! this will fit my needs EXACTLY!
            I think...hehe
            I just need to find the specs on it now...lol
            so can anyone else find the specs?
            I can't find them anywhere on there!
            what SNR?
            what bit converters?
            what resolution?
            Jan Bennett
              EDIT:
              I think...hehe
              what SNR?
              what resolution?
              yeah - this card looks to be perfect...but where are the specs?!?! If the specs are good, this will likely be the last soundcard that many of us CarPC users will need!
              I actually have the card, so at least I can do an evaluation of it.
                more info
                  EDIT:
                  I think...hehe
                  what SNR?
                  what resolution?
                  Only optical out, so SNR info is not available. Didn't notice anything about bit converters. Since it only has optical out, would it have bit converters? Said something about sampling at 48KHz.
                    well that makes sense!
                    thought about it but just wasn't sure...
                    where did you see 48KHz?
                    Jan Bennett
                      Jan,
                      Thank you for contacting the Turtle Beach technical support team.
                      The Audio Advantage is a consumer based USB audio card solution. Here
                      are the available specs:
                      SIGNAL TO NOISE RATIO (SNR): 90dB
                      MAXIMUM PLAYBACK QUALITY: 16Bit/48kHz
                      3D POSITIONAL AUDIO SUPPORT: Yes
                      EAX 1.0, 2.0: No
                      EAX 3.0 ADVANCED HD/EAX 4.0 ADVANCED HD: No
                      DIRECT SOUND HARDWARE ACCELERATION: No
                      UPMIXING OF STEREO TO MULTICHANNELS: No
                      DOLBY DIGITAL 5.1 & DOLBY DIGITAL EX AUDIO DECODING: Pass Through via
                      SPDIF output
                      DTS, DTS ES (DISCRETE 6.1) & MATRIX (6.1) AUDIO DECODING: Pass Through
                      via SPDIF output
                      THX CERTIFICATION: No
                      SPDIF DIGITAL OPTICAL CONNECTOR: Yes
                      Best Regards,
                      Jimmy
                      Turtle Beach Technical Support Team
                      hrmmmmm......
                      Jan Bennett
                        now I'm torn - cds are sampled at 48, but I just can't help but think that the sb Audigy PCMCIA card is a better sounding card...
                        but this thing is so small and perfect otherwise!
                        *sigh* decisions decisions....
                        Jan Bennett
                          I won't be using the optical out of the card - I'm just going
                          miniplug->RCA->line driver->amplifiers
                          So the spec that matters for me (and prolly most others) is the 90dB S/N ratio
                          90dB isn't 'hot' but it isn't terrible either. The SB Audigy 2 NX has a S/N ratio of 102dB. I think I'll stick with the SB. That's a real pitty b/c this turtle beach USB stick is so tiny and even bus-powered. Oh well
                            Well, there's a reason it's tiny and cheap.
                              yeah - i'm probably going to stick with the SB too....
                              Jan Bennett
