A Few questions about Digital Sound with a Carpc
  • A Few questions about Digital Sound with a Carpc
    After my search's and you carpc'ers answering my questions. It seems that playing music through a Digital connection using the motherboard or the soundcards SPDIF OUT is the way to go for SQ in the CarPc. that said and done I will be powering my 2 jl w6v2 12inch and my cdtaudio es620 component's through a digital connect. I wanted to know if a linedriver would be useful in this setup below.
    carpc--->audiobahn dac----->audiocontrol linedriver----->amps is that pointless or does the audiobahn dac boost the voltage? im driving to see if it's worth it to spend this money to get digital sound..you know i can care less about movies..i just want my cd's to play "the same or better" as they do with my currently alpine h/u....I hear spdif is the only way to go..also are their any line drivers that have digital in and analog out? let me know as the audiobahn is $300+ and the alpine pxa-h701 is like $375..I see a ads-4000 for like $100 that has digital in's and analog outs..what would be the downfall in getting the ads? thanks for the help.
    most important question..are their line drivers that boost voltage and have digital input and analog outputs. thanks!!
    audiobahn dac?
    do you have a link to this unit that you speak of?
    (in general, if it has audiobahn on it, it's not going to be good for SQ....and you said you wanted SQ.....)
    the alpine unit that you speak of is JUST the processor, you will need the display if you want to be able to tune the unit at all....
    do you have a link to the ADS-4000 as well?
    Jan Bennett
      What is the model number of thE Alpine processor?
      2002 Mitsubishi Galant
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      Souund Blaster Audigy2 NX
      OPUS ITX PC Case
        alpine PXA-H701 is the model #
        AudioControl Matrix 6-Channel Line Driver can i use this?
        Ads 4000 can i use this?
        http://www.midiland.com/proddetail.a...r=60&category=
        and here is the audio bahn!!
        http://cgi.ebay.com/ws/eBayISAPI.dll...Name=WDVW&rd=1
        please help me..I want to run digital..i will be going from my spdif output on my motherboard to some type of digital IN using optical cables..then from that device, to my AMPS..the big question is..WHAT IS that device? i need a device that decodes the digital and also rase the voltage if possible since I hear that is a much..let me know people.
          The display controller for the Alpine Processor, is it just the faceplate or does it have to go into a din slot? What I mean is, does it take the actual spot or you head unit or is it just the face plate that can be mounted anywhere?
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            it's just a face plate, it's baout an inch and a half thick...it's model number is RUX-C701
            I mounted mine in my center console....you can go to my install page on my web site in my signiture to see more about it
            Jan Bennett
              Thanks Alot. Now how easy it this to hook up? I still need my Audigy 2 Nx rite? Do i just take the SPDIF out from the Sound Card and hook it into the alpine?
              Carputer Specs:
              Via M10K
              512mb Ram
              60GB HDD
              OPUS ITX PC Case
                I don't know about the 4000 since it's ment for home audio...not sure it would handle the car environment all that well...
                as for the audiobahn...ick....I'm not going to remomend anything audiobahn....I can't stand their stuff
                might consider something like this??
                http://www.arcaudio.com/arc-05/processors/peq.htm
                or one of their other products....
                Jan Bennett
                  no need for the sound card if your mobo has SPDIF out
                  it's really easy to hook up, but the tuning can be a bit tricky if you don't know what you are doing....it does come with a mic that will get an approximate tune for you...
                  it's honnestly the best piece avaliable for the money, hands down....I know a LOT of people on here will agree with that
                  Jan Bennett
                    I have an M10k and it doesnt have SPDIF out...So I think i still need the Audigy2 NX. Do I use the Optical Out or IN or do I use the SPDIF Out?
                    Carputer Specs:
                    Via M10K
                    512mb Ram
                    60GB HDD
                    OPUS ITX PC Case
                      Would this processor make noticeable better SQ? And would it be able to make my subs go any louder? My speakers are awesome but i would like a little more bass....
                      Carputer Specs:
                      Via M10K
                      512mb Ram
                      60GB HDD
                      OPUS ITX PC Case
                        this arc audio will give me digital sound? it has digital in and analog out? this is really my main prob, ive read all along the boards and i cannot find a "definite" answer..i hear for good sound quality in a car pc..3 things must be done
                        1. higher voltage with line drivers
                        2. use SPDIF/DIGITAL for premium sound
                        3. equalizers.
                        AM I going to need "3" devices for premium sound??? or is their one device that does it all..or do i need two? people keep telling me about DAC's but nobody knows which brand that is proven..please help me solve my dilema..credit card # itching to order..so far ive ordered my Xenarc 7" TSV screen..
                          Just want to understand how I should hook up the ALPINE processor...
                          I need to use my SB Audigy 2 NX
                          Audigy Optical IN--->Alpine Optical out---> Alpine Analog inputs from Amplifiers
                          IS this how i should Hook it up?
                          Carputer Specs:
                          Via M10K
                          512mb Ram
                          60GB HDD
                          OPUS ITX PC Case
                            Audigy Optical Out -> Alpine optical in -> Alpine analog output (multiple rcas) -> Amp rca input
                              i hope someone gives me the light..red can you help me out here please...
                              thanks
