Protecting subwoofers in the trunk
  • Protecting subwoofers in the trunk
    How do you go about protecting a pair of subs in your trunk? Can you buy grills or guards for them? I'm just afraid that i'll throw some stuff in the trunk and it'll puncture one of my subs.
    thanks
    Audiobahn and kicker both make subwoofer grills. They are more decorative but will provide some protection. Two of my friends had the same thoughts and one bought a grill off of ebay and the other just reverse mounted his subs(alittle more protected, but not much).
    http://search.ebay.com/search/search...lls&category0=
      thanks, i looked around a little bit and found these:
      http://cgi.ebay.com/12-inch-CAR-SUBW...QQcmdZViewItem
      how much protection do you think they offer?
      on the other hand, how durable are the exterior of an unprotected sub?
        Another question, how easy is it to mount one of these subwoofer covers? Are they universal?
        A car without turbo is a car with perpetual lag.
        My Ride
        My New Page
          Drill 4 holes according to the template, mount. They are universal in the sense that when you buy a 12" grill, they will fit most 12" grills.
          2000 Subaru OBS
          Dell P3 @ 900 Mhz
          7" Lilliput TS w/DigitalWW in-dash mount
          80GB External HD
          I am Zero Bitrate....
            Pretty Much. All you need to do is screw the cover onto the enclosure. A sub is fairly strong. But if they are hit with a sharp object the conoe can be pirced. A reverse mounted sub is not as vonerable. But the subwoofer grill will add to the protection of the sub emencly. And if the subwoofer is playing and an object is leaning up against the sub the grill will prevent the sub from being hit or damaged.
              so you're saying that subs are more vulnerable when they're playing music?
              will you get worse performance with a reversly-mounted sub?
                If you have some pricey subs in the trunk YOU WILL NOT be just tossing stuff in there. And if you are the type to just toss stuff in the trunk then subs have no business being in your trunk.
                  Something simple like that works well. Its 8mm stainless steel rods which I bent up to suit.
                  2004 Ford Falcon XR6
                    nice job bob
                    PROGRESS:
                      Do not forget to handle the Phase change 180 deg. after reverse mounted the sub.
                      Just reminding. Sorry if somebody already mention it before.
                        What about the cone hitting the grill when you are pounding out the bass?
                        Sound Stage
                        Eclipse|MTX|Infinity
                          This is almost like bob^s grill but pre made for cheap Link . Had one of these on my old Brahma (28mm one way xmax) with 1100wrms and the cone never hit the grill.
                          Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
                          Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
                            Mine might hit the grille cloth thats covering the sub, but it goes no where near the bars. That isn't a problem as the cloth is very very stretchy.
