ITX sp1300-> AMP wrong resistance?!?
  • ITX sp1300-> AMP wrong resistance?!?
    Im begining to think that i have wrong Ohms from my carputer or something.
    The sound is very high. and i have to set the sound bar in "play control" in the bottom on wave and play.
    Its like the sound amplefies 10x to much :S
    Any recomendation?!? =)
    Ampie Case
    M1-ATX 90w
    EPIA ITX 1,3Ghz, Firewire
    80 GIG SATA
    512MB
    7 TFT Touch Super
    Pioner Slot in DVD-RW writer
    108 Mbit Wireless Lan
    100 M Bluetooth Range
    //Power Nisse
    My Betasite -> http://haagen.se
    what kind of amp is it? sound card?
    first thing is try lowering the gain on the amp.
    then also depending on what kind of equipment you have. make sure you are going either balanced output -> balanced input on the amp or unbalanced output -> unbalanced input on the amp. make sure the setting is correct on both the amp and the sound card.
      i use the intregated soundcard. One 3.5 mm Stereo jack --> rca -> Amp
      im using a Branson amp not a common "brand" but i think it works great.
      oki gonna try to lower the gain on the amp. Thanx
      Ampie Case
      M1-ATX 90w
      80 GIG SATA
      512MB
      7 TFT Touch Super
      //Power Nisse
        going from the onboard sound to the amp is generally not a good idea - the onboard sound usually has somewhere around .5v....most amps need AT LEAST 2v to be worth a damn...
        if you have the gains turned way up, on top of this, the amplifier is just going to amplify any type of induced noise, making it extremely unpleasent for the ears
        Jan Bennett
          Thats was my though. well something about that.
          Do you recomend "CREATIVE SOUND BLASTER AUDIGY 2 NX USB"
          Much Better sound and the right voltage maybe?
          So the low voltage is the answear to the sensitive/high volume + the gain on the amp?
          Ampie Case
          M1-ATX 90w
          80 GIG SATA
          512MB
          7 TFT Touch Super
          //Power Nisse
            not the answer necessarially....
            did you check the gains on your amp? were they up really high? deid you set them like that or did someone else?
            Jan Bennett
              Yes i did check it, Hmm dont se any Gain there. only some balance of the 1&2 and 3&4 channel output.
              The sound is so very sensitive/high! I can record it so you can see for your self. Really strange.
              More people out there wich is running the amp from the intregated Soundcard migh have same problem?!?
              Ampie Case
              M1-ATX 90w
              80 GIG SATA
              512MB
              7 TFT Touch Super
              //Power Nisse
                read something on here about some issue with the volume control in centrafuse, does it happen outside of front end?
