Recommend a small 4 channel amp?
  • Recommend a small 4 channel amp?
    I am trying to find a small 4 channel audio amp for my Car pc installation. It has to be smallish as I want to mount it to my bulkhead behind the glovebox. I guess some about the size of a 1 DIN head unit would be OK.
    It doesn't have to be pretty as it will be out of sight, but all of the amps I have seen are huge showy items.
    It must be possible as a headunit can come with an amp built-in, and 4 x 45W RMS would be plenty.
    Any ideas would be appreciated?
    Happiness is not about wanting what you have, but having what you want. ;o)
    CARPUTER Status
    LCD: K301 (returned!)
    Nano ITX NL10000, 512MB RAM, DVD/CDRW
    M2 ATX
    take a look at this
    amp
    the amps in head units cannot compare .....they are usually just a small integrated ic chip mounted on a piece of aluminum. most hu also tend to misrepresent the actual power by posting the "peak power levels"
    most hu"s are about 20 watts rms with very high distotion and low s/n ratio"s
      Originally posted by sharpy39
      take a look at this
      amp
      Thanks, it looks pretty good. I'll keep it in mind.
      CARPUTER Status
      M2 ATX
