1/8" Audio Out to Speaker Wire?
  • 1/8" Audio Out to Speaker Wire?
    I tried searching but this seems to be a hard one to pull any relevant threads up on due to wording...
    My 2005.5 Jetta already has a nice 8-channel amp integrated into it and I would like to see if it can work with my pc...
    but Im not sure how to go from an 1/8" Audio Out to the Speaker Wire or if it is even possible.
    I need to go from the Audio Out jack to:
    Left Front +-
    Left Rear +-
    Right Front +-
    Right Rear +-
    Thanks in advance... yours truly... nOOb
    2005.5 VW Jetta 2.5L, 1957 VW Beetle Custom
    Previously Owned: 2000 VW Beetle TDI, 1982 VW Vanagon Westfalia, 1971 VW Super Beetle
    My VW Jetta mk5 Carputer
    frodoplayer.com
    mk5 OEM NAV Skin - Frodo - In Progress
    is the computer's sound card stereo or quadraphonic? if it's stereo youll probably need y adapters. as far as the 1/8" out you just need cable with an 1/8" stereophone connector.
    William Surritte, Technician
    No Limit Technologies
    1931 U.S. HWY. 160, Caulfield, MO 65626
    http://home.centurytel.net/nolimititech/
    Planning: |++++ |
    Software Development: |++++ |
    Hardware Development: |++ |
      Its just a plain-jane audio out jack. So stereo.
      If you could elaborate a bit that would be greatly appreciated. Especially concerning the connection of the + -. Im trying to go from the sound out stereophone jack to 8 wires.
      I have a cable with a 1/8" Sterephone jack on one end and RCA red/white on the other. could I splice that and use it somehow?
      frodoplayer.com
        Have a read of this - http://www.mp3car.com/vbulletin/showthread.php?t=32430
        The computer out has 3 wires - Left+, Right+, and Common-
        Your amp apparently has 8 input wires - Front Left+, Front Left-, Front Right+, Front Right-, Rear Left+, Rear Left-, Rear Right+, and Rear Right-
        Connect the Computer Left+ to the Amp Front Left+ and Rear Left+
        Connect the Computer Right+ to the Amp Front Right+ and Rear Right+
        Connect the Computer Common- to the Amp Front Left-, Front Right-, Rear Left-, and Rear Right-
        All you are doing is splitting the output to each input.
        www.debthelpexpert.org
          WOW ok. you can do this but youll get the same sound on two speakers.
          ok youll need a 1/8" Stereophone connector. this is how i would do it.
          If you get the connector here at Radio shack the package will elaborate on the 3 pins
          Planning: |++++ |
            In addition, you have may have to find connectors to suit. The cable you show is fine for the computer end, using the 1/8" Sterephone jack.
              Ha thanks for the input guys... I appreciate it
              frodoplayer.com
                crsseyednsmilin do ya understand all of this
                Planning: |++++ |
                  Well I went searching on RadioShack.com for the connector youre talking about... and got like 500 results. So Im not sure about that.
                  Also... could I just cut open the RCA ends of my 1/8-RCA cable and splice the wires in that way? (PS which is the (-) on the RCA? In or out)
                  frodoplayer.com
                    yeah you can splice it. and the outside of the RCA is the GND.
                    but beware, if the wire is fiber than you could be in trouble.
                    Planning: |++++ |
                      Awesome... thats the route Im going to go then. Ill try and get this done soon and let you know of my results. Thanks a million!
                      frodoplayer.com
                        I might be missing something but should tie Front & Rear Right + to Computer Right+ and Front & Rear Left + to Computer Left+?
                        From the way I read your diagram it looks like you are connecting Front Left & Right+ to Computer Right+ and Rear Left & Right+ to Computer Left+, which would have the left & right chanels assigned to front & rear.
                          Yeah, your right i got that confused!! thanks for noticing
                          Planning: |++++ |
                            No problem It took me ages to try to work out how to explain it... almost as long as it took me to do it on my Probe...
                              yeah, its easy to do but hard to explain
                              Planning: |++++ |
