radio removal - 2005 ford focus
  • radio removal - 2005 ford focus
    ive searched up and down for directions on how to remove the stock stereo from a 2005 ford focus (zx3). this stereo does not have the 4 little holes that the old stereo had so i cant use a ford din removal tool.
    I see no holes whatsoever... Im not a car guy so takin apart the dash would NOT be cool.
    i hope this isnt a dumb question, i try my hardest not to be too much of a n00b.
    Barron
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    i took the HU out of a buddies explorer..i dont know what the focus is like but there was no holes for the removal tool...so it might be similar. you will most likely have to take the dash apart...thats what i did and it came out with easy after that...good luck.
      from Ford...
      2005 Ford Focus ST
        All focus specific questions can be answered at focaljet.com
        Xenarc 7" USB Touch LCD / 3.06 GHz P4 / 512MB DDR / 250GB 7200RPM 16MB HD /
        DS-ATX 220W / Centrafuse / GPS / XM / 802.11g: 6db / RF Keyboard
          yes, but are they factory trained tech's that will jump thru hoops for you and post pics that they arent supposed to distribute? lmao
          2005 Ford Focus ST
            thats excellent. i really appreciate your help. now i just have to figure out how to remove the face plate. i assume it just pops off.
            B Smoov
              pretty much, but they are a PITA to remove cleanly. There isnt much of a place to pry, but you need to find a corner and tug lightly....then work it all the way around. Take your time!
              2005 Ford Focus ST
                [hijack]gospeed.racer, would you happen to pinpoint where on an 03 mustang gt i'd find the vacuum line.. i can't find my owner's manual.. thx.. =) [/hijack]
                Dr. Ron Paul for President 2008
                Hope for America - http://www.ronpaul2008.com
                Who is Ron Paul? - Why do we need Ron Paul?
                CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
                  If you are installing a boost guage or similar, I like to install a tee at the red 90 degree tube at the front of the throttle body. pull the red line from the rubber, and install one end of the tee....connect the other end of the tee to the rest of the red line (cut it down) with rubber hose, and connect the remaining end of the tee to your guage or whatever.
                  2005 Ford Focus ST
                    thanks.. i'll take a look under the hood and see if i can find that.. i'm not installing a gauge, i was just curious as to where the line is located..
                      Little better idea...
                      BTW, that is the throttle body and TP sensor in the background
                      2005 Ford Focus ST
                        thank you sir!
                          i have a pioneer avic-n1 that i am going to install into a 2005 ford focus and i have to wire the pink wire to the vehicle speed sensor, anyone know where that is or if i even have to hook it up, i also heard that i might not have to. any help would be apreciated. THANKS!
                            I found that a paint can opener that you can get for free at Home Depot or Lowes works very well.
