sirius engine wine solution?
  • sirius engine wine solution?
    Hi all 1st wanted to thank everyone who was helping me with my engine wine I had posted before about a month ago got that fixed.
    New problem:
    I am trying to use my Sirius sportster in the car until I can afford the kit to integrate it into the computer and use it with the front-end.
    no mater how I hook it up get tones of electrical interference and engine wine. going into the line-in on the soundcard.
    1: plugged into the cigarette lighter no good
    2 : used the power wire from the cigarette lighter grounded it to chassis as close a possible(12"), straight to battery, in back where I have everything else grounded to i.e. amps,computer inverter no good
    3: used the switched power for the radio grounded it to all the points in #2
    no good
    the only way it works perfect is if I plug in the 120v dc adapter in the inverter and use it that way.
    any other ideas on what I can do?
    Michael
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    i'l tell you if you buy me alcohol... any kind as long as it gets me drunk
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
      homebrew on its way!!!!
      1.)Orion 2500d Amp
      1.)Orion 15" h2 Sub
      1.)Orion 8004 Amp
        Get a ground loop isolator (at radio shack or any car audio shop) and insert it between the line out of the sportster and the line in of your sound card.
