PC to AMP - AMP to Speakers connection
  • PC to AMP - AMP to Speakers connection
    Have searched and have found lots of info on connecting CarPC to Amp but the more I read the more I am confused. I have removed HU and intend using AMP to existing 6 speaker setup. 2 of the front speakers are just small tweaters in the door panels.
    Please advise if cable used to connect from PC to AMP shown in pic below is correct.
    Also require help connecting 6 speakers to amp terminals also shown below.
    That cable may or may not be correct. Typically audio cables have red/white RCA connectors on the end to indicate right/left channels. Yours has a black and yellow one. Yellow is typically composite video (aka TV-out).
    As for connecting the 6 speakers, I don't know. I'm not the car audio guru. But I'd think that a pair of matched components with their own crossover would work as one set of speakers, but that may or may not be what you want in your ride.
    How about the Wiki?
      Thanks... not even sure where I got that cable from. Just found it in my spare pc parts box. May be for my portable DVD player.
