Alpine MRA-D550
  • Alpine MRA-D550
    okay... i was dreaming in the shower.... and this is the first amp i found with optical in.... wow
    http://www.crutchfield.com/S-iiUjJdw...ine+MRA%2DD550
    aint cheap....over 800 bucks.....
    ill keep searchin.....
    geez... i found the thread .... i should read first....
    69 Mustang
    408 clevor AFD 2v heads - Viper T56
    Audio:RUX-C701, PXA-H701, MRV-F545, (2) MRD-M1005, SIR-SC-H1, DMHD1000, Dayton Audio: (2) RS180-4, (2) RS28F-4, (2) RSS265HO-44 DVC
    Yes that amp is pricey, but don't go by Crutchfield's prices. They are always high. Search E-bay or something similar.
    I'm using an Audiobahn ADD51T D/A converter, or DSP, hooked to my computer through an AViC Optical audio cable. The ADD51T will be hooked to my Alpine MRV-F545 4 Channel amp rated at 125w x 4 @ 14.4v. The ADD51T has 9 volt preamp outputs, compared to most car radios that use 3-5 volts so the audio should be very clean.
    Just an idea for you...
    Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
      Yea, i just found that Alpine unit myself, it is on ebay for around $400.
      '03 Acura TL Type S
      Radio Relocation [90%]
      OEM Navi Removal [0%]
      Hardware Acquisition [99%]
      Software Acquisition [100%]
      Testing [80%]
      Installation - ASAP!!
        I purchased mine from Etronics.com for around $390 or so.
