Alpine Headunit Question
  • Alpine Headunit Question
    Ok, here goes: I already purchased an Alpine CDA-9830 headunit from Crutchfiedl:
    http://www.hookedontronics.com/show_...lpine_CDA-9830
    I also purchase an auxillary input adapter to route my sound from the CarPC through:
    http://www.crutchfield.com/S-kTOgARk...0&I=500KCM122B
    Here is the twist:
    I now purchased an Alpine XM Tuner TUA-t020xm off of ebay for a steal (~$36 with shipping)
    http://cgi.ebay.com/ws/eBayISAPI.dll...0040%26fvi%3D1
    My question is twofold:
    a) Does Alpine make a dual aux input adapter? (I couldn't find any)
    b) Since the XM tuner has 1 input and 1 output can I wire it like this:
    Headunit > XM tuner > Aux In Adapter > RCA Out to CarPC
    Thanks in advance for your help
    2005 Black Chevy Impala
    I would think it would work like:
    CarPC>>XMtuner>>Aux In>>Head Unit
      This unit is discontinued, it is not the XMDirect that most people are using. The cable that comes with it is made to go directly to the headunit.
        You should use this KCA121B AiNet instead M-Bus (KCMxxx)
        http://www.crutchfield.com/S-5De00xx...=ainet+adapter
        150 buck multiple input KCA410C
        Or search AiNet adapter on crutchfield.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          I don't understand why you recommend this over the one I already purchased?
          I think this is exactly what I was looking for...thanks
            The Ai-Net allows for two Aux Inputs, its well worth the 100 you'll spend on it. Can hook use your Ipod also. Thats the setup I have, and great price on your XM radio.
            Jeep Grand Cherokee Laredo
            Kenwood X790 x/ iP500 Ipod Interface
            Elemental Designs 13Kv.2 D2
            CDT ES-620 (omg yayay!!!1)
            NINe.2X, NINe.2
              Your Alpine CDA9830 (I have same one) uses AiNet. The one you purchase is for M-bus HU. The connectors are different between 2 protocols.
              Unless you bought a KCAxxx and thought it was a KCMxxx. They do look the same/similar.
                I purchased the right one, just linked the wrong one. I also found this while searching; a little cheaper than $150 Ai-Net device, but if everyone tells me that it is better I will buy it. Check this out:
                http://www.discountcarstereo.com/detail.aspx?ID=321
                  Bump...any advice before I place an order?
                    Can you also have digital optical aux in in pxa-h700??
