"XM Ready" is waaay too confusing!
  • "XM Ready" is waaay too confusing!
    Ok, my Alpine 9830 is "XM Ready". I guess i need the tuner and the antenna. But now I see a "digital adapter". do I need the alpine digital adapter also? The XMD1000 is the tuner+antenna kit I want. I also see the adapters for alpine, sony etc... do I need one of these also? Thanks
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
    You will need the XM adapter to hook your XM direct to your HU......
    or you can use your XM adapter as an Auxillary in for your HU...in other words, the sound from your computer will go to your XM adapter and your XM will run through your PC......
    Does this help?
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
      right, i need the tuner and antenna, i knew that. what is with this "digital adapter"??? i thought that you can just connect the tuner to the xm ready deck and be good to go.
      2005 Dodge Ram HEMI
      15" LCD touchscreen
      Mac Mini
      Modded Xbox
        No, you can't.... generally speaking.
        The Adapter is required to "adapt" the direct to your XM ready deck.
        My pioneer deck uses the P-Bus plug from the deck to the adapter and 12V power... the adapter has an input side for audio, and 8(?) pin din plug from the XM direct...
        But, I use the audio in. The audio comes from the PC.
        If you are using the XM on ly, the 8pin goes from the XMD box to the adapter. The audio goes from the XMD to the Adapter.
        The adapter plugs in to the HU using a propietary bus cable from the HU manufacturer. In my case a P-bus adapter cable.
        In other words you need some sort of adapter to communicate the data from the XMD to the HU.....
        The computer does this in a Car PC setup..... much better, in my opinion.
        Status:
        Custom enclosures
        Newbie Guide
          thanks alot man, so i need the alpine adapter also... thanks!
          2005 Dodge Ram HEMI
          15" LCD touchscreen
          Mac Mini
          Modded Xbox
            Alright I know this, I sell and install these things everyday. Some maybe even most alpine HU are both XM and SIRIUS ready, even though your model states "xm ready" some of the equiptment
            You have 2 options
            1. if you want Sirius they make a kit for AI-net interfaces in one package for just $100
            2. If you want XM, you have to get two pieces:
            a. Terk's XMD1000 universal tuner for $50
            b. Terk's XMDALP100 alpine smart digital addapter for $50
            Like i said both should work in most alpines that have an AI-net plug. I've never had a problem hooking thoes up to the alpines that just say "XM Ready" opposed to now where they say "Sat Ready." They're the exact same price, easy install. Now you my have a choice between services.
            PROGRESS:
              on ebay i can get the pair for $70 shipped and there is a $50 rebate on the tuner. i want XM beacuse we use it on other cars in the family and there is a family plan so we can get it cheap.
              2005 Dodge Ram HEMI
              15" LCD touchscreen
              Mac Mini
              Modded Xbox
