Monsoon system in VW Jetta. HELP!!
  • Monsoon system in VW Jetta. HELP!!
    Hey everyone,
    I own a 2002 VW Jetta. it has a factory monsoon system in it with the factory amp and all that stuff. This past christmas, i got a pioneer DEH- P80MP Head unit. when i went to have it installed, i ran into some trouble. apparently i would have to rewire my car speakers and replace at least the front two speakers and possible the rear two speakers all to bypass the factory amp in the car. this ****ed me off terribly. does anyone know what i should do? i really want to put my head unit in my car because i have an amp and 10'' sub. I have been given advice to just leave the factory player in the car because of the hassle to replace it. has anyone replaced a monsoon system for an aftermarket radio? I was also wondering how complicated this job would really be. if anyone could help me out, that would be awesome. thanks!
    Originally posted by SteveT178
    Hey everyone,
    First of all, this is a carputer forum. But, be that as it may, SEARCH this forum. This has been covered, and it isn't that hard. Just got to search for the answer.
    Michael
      you don't "have" to bypass the amp. go to www.bestkits.com and enter in your car info. it will show you the necessary adaptors you need to make your radio work with the monsoon system. BTW...I just did an 03 Jetta and it used a bmw harness and that was all that was needed.
        The Monsoon system is different. You can't just get an adapter and install an aftermarket HU because the Monsoon amp requires 6 volts ON THE SPEAKER LEADS to work. Since his headunit doesn't provide 6 Volts, in addition to the speaker outputs, it WILL NOT WORK with just a harness as you suggest.
        The OP should search for the answer, and if are interested, you should search as well.
        Michael
          ok
          I imagine there are a couple of different monsoon configurations because the 03 Jetta we worked on yesterday uses a 9008 harness and was a direct plug in.
            there are aftermarket adapters for the monsoon system.... they are very commonly available... Take your car to a different audio shop.. one that knows what they are doing...
              Was it a monsoon? I doubt it. The monsoon is not your regular stereo, it is an upgrade.
              WHile there are many aftermarket units, it can be built for about 5 bucks quite easily.
              Michael
                Michael
                yeah but why build it for $5 when it only costs $10 ??
                http://www.metraonline.com/product_listing.php
                you need either the 70-9003 or the 71-9003 its hard to tell from the pics and my memory...
                edit: the 70-9003 plugs into the car harness and the 71-9003 plugs into the stock radio... in case you wanted to transplant the stock radio to another car???
                  Because that is not what he needs to use the Monsoon Amp.
                  The monsoon amp is a different beast all together.
                  Read here
                  http://www.mp3car.com/vbulletin/show...hlight=monsoon
                    Dude.. I was one of the first to install the non -monsoon navigation systems from europe into a monsoon equipped car in the US...
                    I used this adapter and it works... I however had to run a seperate ignition wire to the headunit... since the factory harness does not have one...
                    you can search on vwvortex.com if you want.. my user id is strohj on there as well
                      You know what. You may have, or you may not have,
                      got this when I tried a search on the name
                      Error
                      » No Results Found
                      No search results found. Please try different search criteria or a different data set.
                      » Go Back
                      and then I got these
                      VWvortex ForumsSearch18 topics found
                      » Search Results
                      Your search returned 18 results.
                      » New Search
                      Topic Forum Date Posts
                      WTB: 337 lower rear valence
                      Forum » Golf IV/Jetta IV Classifieds (OLD)
                      Creator » strohj 11:01 PM 11-7-2003
                      by strohj 3
                      337 with OEM Navigation For Sale!!!!
                      Creator » strohj 6:48 PM 10-12-2003
                      by JunioR_VW 31
                      Anyone getting harassed by cops a lot? ( 1 2 3 )
                      Forum » The Car Lounge
                      Creator » strohj 11:04 PM 7-24-2003
                      by Villan 102
                      Kenwood CDX-869 + Sirius + Keg = Keg not working ??
                      Forum » Car Audio & Electronics
                      Creator » strohj 7:27 PM 6-12-2003
                      by Nash50 2
                      WTB: 18x7.5 OZ Superturismo's
                      Forum » Wheels and Tires Classifieds (OLD)
                      Creator » strohj 1:51 PM 11-28-2002
                      by 16vPowers 6
                      VAG COM plug question
                      Forum » GTI 337/20th Anniversary/Jetta GLI Forum
                      Creator » strohj 6:47 PM 11-18-2002
                      by strohj 2
                      WTB: GTI rear spoiler
                      Creator » strohj 3:22 PM 11-13-2002
                      by strohj 3
                      337 by Best buy Almeda?
                      Creator » strohj 10:14 PM 11-10-2002
                      by strohj 1
                      Completely OT... but its hilarious and i had to share it with you guys!
                      Creator » strohj 2:51 PM 10-22-2002
                      by FrankiEBoneZ 3
                      Adding the Euro Navigation system to it
                      Creator » strohj 2:31 PM 8-22-2002
                      by TreyS 33
                      Parts for my car?
                      Creator » strohj 8:47 AM 8-8-2002
                      by strohj 1
                      MP3 Cd changer????
                      Creator » strohj 12:56 AM 7-18-2002
                      by voiddweller 8
                      ok i got my flamesuit on....
                      Creator » strohj 3:06 PM 7-17-2002
                      by RonN 13
                      RoofusX's catr and the nice pics
                      Creator » strohj 1:17 PM 7-9-2002
                      by [email protected] 5
                      some possible mods...one day
                      Creator » strohj 6:13 PM 7-3-2002
                      by strohj 1
                      337 in Houston
                      Creator » strohj 4:03 PM 7-2-2002
                      by strohj 1
                      Any chicks getting the 337? ( 1 2 3 )
                      Creator » strohj 1:46 PM 6-7-2002
                      by '97Trek2.0 71
                      I can't believe this ....
                      Creator » strohj 12:35 AM 6-7-2002
                      by Nikon101 5
                      I read the only one that had anything to do with Navi, and there is nothing in there about you accomplishing it in your car with a Monsoon system.
                      If you point out the link, I would enjoy reading it.
                      Michael
                        In an '02 the 70-1780 harness should plug right in, no extra work needed. I'm pretty sure the Monsoon system uses current sensing to turn on, so there's actually nothing to integrating an aftermarket headunit. The speakers are all 2 ohm, so if you want to replace those you'll have to bypass the amp, which is underneath the rear deck.
                          The answer is in post number 9. Thanks, Michael.
                          Want to:
