5 channel amp + mono driving CENTER speakers?
  • 5 channel amp + mono driving CENTER speakers?
    Sorry if this is obvious, but virtually everywhere else I've looked including search) it seems that people trying a "6 channel" or dual amp config is driving 4 speakers and a sub, with the sub on the mono or bridged channel.
    Anyway, my car has 6 speakers and a sub. I've been running the dash speakers off one channel (since they act as "center" in my arrangement for audio and 5.1 DVD and mono is fine) and my sub off of channel 6. That caused a few headaches, including the need to put inline filters on the center speakers because I can't do a pass filter effectively with the small high-freq dash centers pairing with the sub on channels 5/6.
    Anyway, my amp seems to be questionable these days, and I was thinking I should just do a 5 channel amp, using the 5th channel to drive my centers instead of the more traditional thinking of a sub. Then use a mono amp to drive the sub. Thoughts?
    There is another girl with a thrunderbird doing what you're doing. I can't tell you exactly why the are doing it that way other than teh seemingly obvious 1) their car came with 4 speakers adn they didn't want to add more, and 2) it was an easier set up than a multiamp one.
    You have 6 speakres. I'm not sure about your audio card, but if you have a 6.1 sound option, i'd say go for it for the hell of it. I'm not sure if it can hurt. Get a 6 channel amp at 6.1 surround if your dash speakers are spread apart, or a 5 channel at 5.1 surround if they are close together, and a seperate sub amp and call it a day after wiring it up. IMO, that seems like a decent approach to it
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
      no reason it wouldnt work. Using a monoblock means you've got a bigger selection of good powerful amps to run the sub.
      only concerns are
      With 5 channel amps the 5th tends to have a low pass filter - you'll need to make sure you can switch this off and then add an external high-pass on the signal
      THey also are usually a more powerful than the other 4. You'll just need to be careful you dont overpower the centre speaker.
      Mazda 323 with XBOX based SQ system
      Running Xbox Media Center
        or use an 8 ohm speaker as the center channel. That would half the power difference. Find a speaker low in efficiency and you are pretty close.
        Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
