How do I time the speakers
  • How do I time the speakers
    Well the advantages of using a computer to play your music are very high, and makes me interested in SQ events.
    What do I need to do to make sure the soundwaves are coming at me like they should. Seems like software can offset the speakers a bit to make them all seem equal, I just don't know how to do it, or what I need. That's why I'm coming to you guys
    Budd
    high quality sound card software.
    soundblaster XFI works well.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      a ruler, software/processing that can adjust the timing and a calculator. You will want to know this number as well: 13548 in/sec.
      You will have to take it from there McGuyver
      Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
        learning to tune isn't exactly something that can be explained over the internet IMO.
        You have to sit down with someone who knows what they are doing, and have them point out some things to you.
        You also need to know what the music SHOULD sound like, along with knowing the certain things you need to listen for
        Jan Bennett
          Thanks Alti and Will, and point well taken Red GTi.
          I'd love to find more like minded people locally, but the fact is, there are only two stereo shops, and none of my friends have an interest in the speakers.
          I'd like to check out SQ events close to me in Michigan.
          Seems like you could almost put a mic where your ears would be, hit the go button, and it automaticly calibrates it for ya. I guess we're not there in technology yet.
          Also I'll look into some good sound cards. Thanks again guys
            Pioneer and sony both made processors like you are saying - where a microphon is placed. VERY expensive
              The alpine PXA-H701 with the corresponding display (RUX-C701) comes with a mic that will get you at a starting point, and might be very beneficial when you don't have ANYONE near you. It's not going to get your set-up 100% perfect, but it will get you on your way at least. (no one's set-up is 100% perfect anyways, speakers change their characteristics as they are used).
              You can buy the alpine I'm talking about for about $700 at retail, some people are finding theirs on ebay and the like for around $500...
              don't know what kind of a budget you are looking at, but for the money, PERIOD, there is nothing better out there
              do a quick search for H700 or H701 on here and you will see what I mean.
              Jan Bennett
                PS: as for shows look at the following:
                http://www.iasca.com
                and
                http://www.soundoff.org/usaci.htm
                there are a few others out there, but they aren't as well known or as big
                Jan Bennett
                  I've found the KX drivers for Sound Blaster cards (not the USB Audigy, unfortunately) work very well for fine tuning the sound. You can do a variety of things, including time alignment, individual gains on each channel, etc. If you can't afford the Alpine (which I couldn't), then this isn't a bad option.
                  The website is:
                  http://kxproject.lugosoft.com/index.php?skip=1
