Some advice on amp for subs
  • Some advice on amp for subs
    Hey just bought two new 12" Alpine Type R, and they are rated at 500W RMS, and i was looking for an amp today to handle them.
    Would two of these do?:
    KENWOOD KAC-9102D 1700 WATT MONO AMPLIFIER
    # Amplifier Type: Mono
    # RMS Power: 500W x 1 @ 4 ohms
    # THD at 4-Ohm RMS Power: 0.08 %
    # RMS Power: 850W x 1 @ 2 ohms
    # Speaker Level Inputs: Yes
    # Preamp Outputs: Yes
    # Built-In Crossovers: LP
    # Bass Boost: 0 - 18 dB
    # Frequency Response: 5-200 Hz
    # Signal to Noise Ratio: 100 dB
    # Fuse Rating: n/a
    Cheers guys...
    Why 2? Why not just run one? Yes, two would produce more power than one (about 15%) but is it worth 2x the cost and current draw?
    Keep in mind that since the 2 speakers can handle 1000 watts, and the amplifier produces 850 at 2 ohms, does not mean that the speakers can handle whatever you toss at them. You still have to pay attention to distortion.
    Also, that power rating is probably for a sealed enclousre with 1.25 cu/ft per speaker. That number lowers when you use a ported or bandpass enclosure
    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
      Type R subs deserve better
      Jan Bennett
        (read as what she said)
          What would you suggest mate? Well i love my base and thats why i bought two...
          Also i don't want to waste these subs in a universal box, should i make one up or will any car store be able to do a better job?
          thanks
            thanks
            http://cgi.ebay.com/Brand-New-in-Box...QQcmdZViewItem
            New System in progress:
            M10k
            Phaze TD1500 ~> Seas g18rnx/p
            Zapco Ref 500.1 ~ 12" tc-9
            Transflective Xenarc
            My Car Pc Install
            My Boat Pc worklog
              I would suggest something a little more high end than a Kenwood
              JL AUdio
              Alpine V12 (2 of these would kick ***: http://www.alpine-usa.com/en/product...model=MRD-M605 or if money is an issue: http://www.alpine-usa.com/en/product...model=MRP-M650 two of those)
              The PG would work
              I have just never been a big fan of Kenwood...they make OK product, but that's about it IMO, nothing great.
              Jan Bennett
                if you can swing it: http://www.alpine-usa.com/en/product...odel=MRD-M1005
                would probably work, but I understand it's "expensive" to some budgets
                just don't skimp on the amp, whatever you do, don't skimp on it!
                Jan Bennett
                  Hey, would you consider these kenwoods skimping?
                  the amp you suggested second only puts out 400W x 4ohms (0.08 THD) and 600W x 2ohms.
                  the kenwoods are 500W x 4ohms (0.08 THD) and 800W x 2ohms?
                  Sorry i don't understand this, are you just going by the quality of the brand, because i got the impression more RMS Watts to the sub = Better.
                  I was looking at buying one Alpine V12 and running them both from that, but im sure the 2 kenwoods would be better?
                  Cost is a thing for me, i didn't want to cap $2500AU when setting up my system:
                  Already bought:
                  Sony Xplode Headunit: $370
                  Kicker 6x9" Speakers: $100
                  2 x Alpine R Type 12" Subwoofers: $565
                  Still Need:
                  Kicker 6" Speakers: $115
                  2 x Approx. 500W RMS Amps: $700
                  Touchsreen 8" Moniter: $350
                  Wiring & Installation: $300
                  Sub Boxes: $150
                  thanks guys...
                    Sorry, would this Kenwood be better than the one i first suggested, i would have to bridge both of them, but its cheaper and says it would output 500W @ 4ohms the same as the first one...
                    KENWOOD KAC-7252 1000 WATT 2-CH AMPLIFIER:
                    # Amplifier Type: 2-channel
                    # RMS Power @ 4 Ohms: 170W x 2 @ 14.4V
                    # Bridged RMS Power @ 4 Ohms: 500W x 1 @ 14.4V
                    # Built-In Crossovers: HP/LP
                    # Frequency Response: 10-45,000 Hz
                    # Fuse Rating: n/a
                      I wish it were as simple as wattage, but it's not
                      wattage deffinately matters, but it's not the end all be all in car audio, there are a lot more things to look at
                      chances are the Kenwoods aren't CEA2006 rated, the alpines are - which means the power claims by the kenwood aren't guaranteed, the alpnes power ratings are
                      btw - which version of the subs did you get? dual 2s or dual 4s? because that will make all the difference in the world.
                      hands down the alpine v12 is a better quality product than the kenwood
                      each amp that I posted is an option
                      your sub configuration will determine which amp you need to go with
                      Jan Bennett
                        They are the "Dual voice coil 4ohm x 4ohm"
                        How would this be to run both subs:
                        PHOENIX GOLD XENON 1200.1 AMP 1200W RMS:
                        High efficiency (greater than 80%) Class D Operation
                        Buffered RCA full range thru output
                        Remote Monitoring Display (RMD) port
                        Low Pass Level control ready (LPL-44)
                        1200W X 1 RMS @ 1-4 ohms
                        thanks
                          sure, if you're trying to keep things cheap
                          Jan Bennett
                            Not the answer i was looking for....
                            Heres the simple question:
                            What would be better to run 2 x 12" Alpine R Type Subs?
                            1 x PHOENIX GOLD XENON 1200.1 AMP 1200W RMS
                            or
                            2 x KENWOOD KAC-9102D MONO AMPLIFIER 500W RMS
                              which one has more fusing built in?
                              two $300 amplifiers does not equal one $600 amplifier
                              two $400 amplifiers equals one $600 amplifier
                              in a general sense
                              I honnestly do NOT like Kenwood. IMO they don't make a quality product. It's a mid to low level product. PG on the other hand....at least makes a half decent product.
                              Jan Bennett
