Wiring ignition line
  • Wiring ignition line
    So I was thinking about this last night because this project has totally emcompassed my conscious and unconscious thought patterns continuously, I have 2 devices that need to use the ignition wire to determine when to start.
    I have an amp in the trunk that needs a delay to start after the ignition line goes high.
    I also have an M2 that needs to start, but without the delay.
    What type of wiring and/or relays and devices would I need to power such a situation?
    What should I use to split the ignition line to drive those two devices?
    Thanks for your help!
    M2-atx?
    or what m2 are you talking about?
    if you're not talking about the m2 power supply, you should look into getting either it or a power supply that has the amp turnon delay built in (which the M2 does)
    Jan Bennett
      Originally posted by Red GTi VR6
      M2-atx?
      I am talking about the M2-ATX power supply
        ok - so then...it's already got an amp turn on delay built into it...IIRC
        the M2 will turn on the computer only after it sees a regulated voltage coming in...
        then it waits a but before it sends the turnon to the amps...thus the anti-thump technology
        it's the same withthe M1-ATX in my car
        no delay circuit wired into the car...it works like a charm
        Jan Bennett
          Wow, I am an idiot and just read the directions. That makes a lot of sense :-P
          Thanks!
            np! it happens to the best of us!
            good luck with it all!
            Jan Bennett
