1996 Chrysler Concorde front speakers not working
  • 1996 Chrysler Concorde front speakers not working
    I have tried to installed a radio but the rear speakers are only working and they sound like @#$%
    i tried disconecting the dash speakers and only have the door working but nogo
    i know it not the radio
    i hooked up a old speaker and it sounded great i
    f i have to rewire the system i will
    3.5 dash
    5.25 door
    6x9 rear
    my factory radio is
    6-PRESET RADIO WITH BASS & TREBLE SLIDER CONTROLS, "DIRECT DISC SELECT 1-6" PRINTED ABOVE RADIO PRESETS, AND “MODE/EJECT" BUTTON
    i dont have a factory amp
    2005 Pontiac G6
    Headunit: AVH-P3100DVD
    Front speakers:Infinity 6022i
    Rear speakers: Powerbass pb-b6.5xv.2
    Battery: top of line walmart brand(LOL)
    Wiring: 1 run of 0 ga
    Amp: MTX JH600 & Lightning Audio B300.4
    Sub: TS-W2000SPL
    Did you use an adapter harness or did you cut the old harness off and hardwire it?
    How do you know there is not an amplifier? Did you replace the speakers?
    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
      i use METRA 70-1817 http://www.partsexpress.com/pe/showd..._ID=6568&DID=7and i check the wire dirgram for a 93 its the same
      i dont think its a amplifier system it dont have Infiniti on the factory radio but i will check under the seats and in the trunk and get back to you
      2005 Pontiac G6
      Sub: TS-W2000SPL
        I would go back to the harness with a multimeter and check the factory speaker wires for the impedence of each speaker. You have an issue if you dont find around 4 ohms for each.
          i was getting .43 ohms
          so i check out the trunk what i thought i was the car ecm i was a amp
          any ideas of bypassing it
          2005 Pontiac G6
          Sub: TS-W2000SPL
            i going to try to connect the blue wire from the OEM harness to the amp remote wire
            2005 Pontiac G6
            Sub: TS-W2000SPL
              I wouldnt recommend that
              You need to figure out which wires are which at the amplifier. You then hard wire the speaker in to the speaker out.
              Much easier just to run new speaker wires from the head unit to the speakers.
              I would NOT run the radio as is. You run the chance of frying th fragile output section. Figure about a $100 repar bill
                ok i got it working i hooked up the remote wire on it work
                thanks for all your help
                2005 Pontiac G6
                Sub: TS-W2000SPL
