Sound deadening...
  • Sound deadening...
    Hi,
    I'm wondering if anyone has used barrier matting (lead-impregnated rubber matting!) in a car before, and if so how well it works. A friend did say that I can't put it anywhere near the exhaust, or possibly even the floor above it. I could put it on the first layer of mats (already weigh some 8kg each), but below the top dressing mat, or is it better when in contact with the vibrating metal itself? Definitely some :
    On the transmission tunnel (2 layers)
    the whole rear floor (80"x36" or thereabouts)
    on the rear wheel wells
    and under the driver and passenger mats and on bulkheading.
    He also mentioned some kinda spray-foam? which is this?
    1996 Volvo 850 T5 CD - Eventually I'll start....
    I've never used it, but it should work. Remember, all you are trying to do is to stop rattles by increasing mass. A good spray foam that is used for sealing off compartments is called great stuff. I don't know how good it is at sound deadining though.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
      but it can't be put in the doors, lol the window won't work
        I've used some stuff I found at my local home improvement store called "Quick Fix" gutter repair tape:
        I think there is similar stuff called "peel n' seal". Both products are made for roof repair I believe. Here are a few pics of my car interior with the deadener installed:
        WORKLOG
        Webpage
          How well does it work? much road noise?
            I used Peel'n'seal. Its great accually, proably the best money I have spent on my Jeep. I put down two good layers and three over the wheel wells.
            Jeep Grand Cherokee Laredo
            Kenwood X790 x/ iP500 Ipod Interface
            Elemental Designs 13Kv.2 D2
            CDT ES-620 (omg yayay!!!1)
            NINe.2X, NINe.2
              Not just that, rubber type products absorb vibration. Steel is much more massive than rubber but if you bang two pieces of steel together they will chime or resonate; two pieces of rubber banged together won't.
              homebrew sound deadening + sub and amp install... 04 Dakota QC
              fuel economy calculators
                presumably it's quite good (the foam) as it contains loads of air, which can trap sound. Right, I was belting downthe motorway at 90+mph and I wondered why i could barely hear myself think - I'd left the 2" thick rubber deadening mats at home for the Roadworthiness test (which it passed BTW )
                  I used the stuff in my trunk, works very good. killed all rattle from the subwoofer. Also now if u knock on the trunk, it sounds solid... knock on the doors its tingy. i will do the doors next.
                    Snootch, how much did that stuff cost you and how much do they give you?
                    Peel 'n Seal recently must have gone up in price. I used to pay $10 ish, then $12.47, now its $13.68.
                    NINe.2X, NINe.2
                      wait wait wait...2 INCH thick deadening? Like 16 pounds/sq. ft.????
                      Chris Schempp
                      Elemental Designs
                      Scion tC in progress
                        Oh yeah. each weighs the best part of 10kg (2.5ftx4ft). about an inch of rubber, then some other stuff contouring into the corrigation in the load bay
                        Now I'ma big guy (6-2, 200lbs) and I find it difficult to carry both, mainly because of size, but they aren;t light lol
