using speaker wire as power wire
  • using speaker wire as power wire
    just was wondering if it would be ok use 12-14 ga speaker wire for low power accessories or is it a big "NO NO" for a 7" monitor or slot load dvd etc..
    I was just wondering because it seems like it is hard to find good quality 12-14 ga power wire (lots of thin strands) seems like they all are very course..and there is lots of good quality speaker wire that gauge..Very flexable Plus all you have 1 wire to mess with.
    If not what is the reason that you should'nt.
    Is the wire or insulation any different between speaker wire & power wire?
    Just was wondring.....
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    Why not?
    7" monitor and dvd doesn't require lot of current.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      At 12-14V, insulation is not an issue - the gauge and current draw will determine how much the wire heats up.
      For little stuff, that gauge is probably overkill - will work fine.
        Speaker wire is a good solution when you need to run both hot and gnd together. Wish I would of thought of that.
        BTW, I have found the best place to buy wire and wire connectors is home depot
        My Work Thread:
        Source switcher for Lill
          i use a 100m roll of speaker wire i purchased a coupke of years ago, i use it for everything!
            i used speaker wire to wire up **** on my bike :-)
              i'm going to do the same thing for my screen & backup cam.
              Final Touches
              Car: 2002 Mitsubishi Magna EI
              CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
              Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
