***Big 5 or 6 channel amps***
  • ***Big 5 or 6 channel amps***
    Post some of the biggest and baddest 5 and 6 channel amps that you all know of. Here are some examples of some solid amps that you could use for a one amp setup:
    DLS Ultimate A7: 5 channel amp rated at 60 X 4 @ 4 ohms and 200 X 2 @ 4 ohms (bridged)...it's mono channel is one ohm stable and rated at 600 watts X 1 @ 1 ohm.
    Here's a link: http://ampguts.realmofexcursion.com/DLS_A7/
    The DLS would be perfect for some components up front and one solid 12" sub.
    Memphis Belle 5 channel: 5 channel amp rated at 75 X 4 @ 4 ohms and 300 watts X 1 @ 1 ohm on the 5th channel.
    Here's a link: http://memphiscaraudio.com/products/...cat=&id=29&p=2
    The memphis amp would be good for a decent 4 speaker setup with a sub that can perform well with 300 watts @ 1 ohm.
    Rockford Power1000:
    Front/Rear Channels (class A/B)
    50 W x 4 @ 4 Ohms
    100 W x 4 @ 2 Ohms
    150 W x 4 @ 1 Ohm
    200 x 2 W @ 4 Ohms Bridged Mono
    300 x 2 W @ 2 Ohms Bridged Mono
    Sub Channel (class B/D)
    300 W x 1 @ 4 Ohms
    600 W x 1 @ 2 Ohms
    800 W x 1 @ 1 Ohms
    The Genesis Profile 5 Ultra:
    100 x 4 @ 4 ohms
    200 x 4 @ 2 ohms
    350 x 1 @ 4 ohm
    550 x 1 @ 2 ohms
    In 3 channel configuration: 200 x 2 @ 4 ohms + 350 x 1 @ 4 ohm/ 550 x 1 @ 2 ohms
    Those were the only ones that i found....post what y'all heard of...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Man Ive got a list some nice older amps
    Mcintosh
    mc4000m 100x4 +300X2 @4ohm
    mc440m 100x6 @ 4ohm
    MMATS
    MPA5400 100x4 + 500x1 @ 4ohm
    A couple newer amps
    Cadence
    VA500 100x4 + 300x1 @ 4ohm
    Phoenix gold
    octane r9.0:5 125x4 + 400x1 @ 4ohm
    these are all I can think of at the moment
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
      those are some nice amps boomintrac!
      Jan Bennett
        I wish I still had my mc4000m but that was long long ago THIEVES SUCK! that was all he was able to get out before the cops showed up. thank god I had an alarm or my neighbor would have never known to look. the theif droped the amp and tried to run the amp was all scratched up and the apperance wasnt that hot anymore that I just sold it
        Aron
        New Ipad
        Zapco DSP-6SL
