Sub connection advice?
  • Sub connection advice?
    Here's what I have:
    Infinity Reference 5761a 6-channel amplifier
    JBL GTO Series 1002D Dual Coil Subwoofer
    What's the best way to go?
    1. Use the amp bridged into a 4-ohm load and
    a. Connect the sub in parallel, or
    b. Connect the sub in series
    or
    2. Use the amp in 2-ohm stereo and connect each coil as a seperate subwoofer
    Thanks!
    -Meta
    ChadGoode.com - Miata MX-5 Carputer
    ChadGoode.com - Nissan Frontier Truck-puter
    that sub comes prewired as 4 ohm, so just leave it in series and connect it at a 4 ohm load
    should be good to go!
    Jan Bennett
      Thanks! I did just that and it sounds great.
        Jan Bennett
