TV Antenna Signal Wire
  • TV Antenna Signal Wire
    Looking to put TV antennas in the trunk lid behind the liner...
    so I need to route the signal wires to tuner in front.
    Should I keep the signal wire(s) away from other electrical harnesses to avoid "distortion" ?
    I'm not sure if I should route the wire along either side of the car, where there is big thick harness or thru the middle under the carpet.
    thanks
    Back from Brokeback Mountain
