two touchscreens pls help
  • two touchscreens pls help
    i need some help. i just bought a truck and want to install two vga touchscreens in my sunvisors. i want to be able to use either moniter, for example if the passenger wants to select a song on my car computer i want to be able to use the passenger moniter, or vise versa. i want both moniters to view the same thing and be able to make a selection on either moniter. hope that makes sense any help would be appreciated. thank u in advance.
    All you need is a VGA splitter so they'll show the same thing.
    How about the Wiki?
      the moniters use usb for the touchscreen part. how would i go about doing this? would i just plug both them in seperate usb ports? im new at all this stuff.
        makes sense to me
        but what does this have to do with car audio?
        wouldn't this belong in the screens section?
        Jan Bennett
          yeah it should work the same way as having to monitors hooked up t your home computer as well as 2 mice hooked up, both mice would work independently of each other.
          replicant
          Audi A4 (flickr pics)
            merde! this has been asked many times before!
