Audio formats supported by OEM HU cd players?
  • Audio formats supported by OEM HU cd players?
    Hey guys,
    I have a quick question and I don't have time to do a bunch of searching and reading. A friend is over and wants a copy of an audio book I have, which is recorded as an MP3. She has the factory stereo head unit in her truck.
    What format should I record this audio book onto cd so that it will be compatible with her HU. Should I use MP3, WMV, etc?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Little confused.... but unless her factory unit specifically says it will play an mp3 or wma cd then you'll need to burn as a normal audio cd.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
      nkotch,
      What format would a normal audio cd be? Is that a cda format?
      8" Lilli TS
      MB896F Mini-ITX MB
      1GB SDRAM DDR2 533
      3COM BKP Cam
        Correct me if i'm wrong, but i think standard CD format is .WAV
        But your CD will have to be burned as an audio CD, not a data .WAV
          Yea, CD-DA or RedBook. What are you burning it with? Doesn't it have an Audio CD profile/format?
          EDIT: Just looking at the above post..... yea, the audio file should be in the .wav format, those usually a burning program can use most audio formats to burn an Audio-CD, it just first converts the file to a .wav and then burns it. But you can't just burn the .wav file to a cd like omega said, that's just a data cd with a file on it.
          Nick
            Okay, so I convert it to a .WAV and burn it as an audio format. Perfect! Thanks guys.
            8" Lilli TS
            MB896F Mini-ITX MB
            1GB SDRAM DDR2 533
            3COM BKP Cam
              Any burning software I have ever used has had the option to burn as audio cd (even from .mp3). So it should convert it to cda format for you.
              My Work Thread:
              http://www.mp3car.com/vbulletin/showthread.php?t=72552
              Source switcher for Lill
              http://www.mp3car.com/vbulletin/show...d=1#post841007
