best wired fm modulator
  • best wired fm modulator
    I've gone through all the possible options...and i've finally come to the conclusion that i need a wired fm modulator.
    I'd like get everyone's opinion on what the best ones to use are...
    I know there are a lot of them out there, but I was just curious if anyone had some recommendations...
    Thanks!
    Car: 2002 Nissan Altima
    Computer: Powerbook G4 12"
    Current Status: 7 %
    - audio inputs are done!
    - front row is installed!
    Current pics of my install
    do a search - this has been covered numerous times...
    IMO - not a single one is worth a damn.....but others disagree..
    search....and ye shall find
    Jan Bennett
      I have had good luck with the audiovox.
      It would be best to find another answer though.
      TruckinMP3
      Read the FAQ!
        The problem I have found with FM transmitters (both wired and wireless) is noise gets into the system when you power them off the car battery. Otherwise I get a clean signal when I power them off batteries.
        I have no intention of having to change batteries every week or so. The car computer setup is supposed to make my life easier, not harder.
          Tried powering it from your PC's PSU?
            Then you are doing something wrong.
            TruckinMP3
            Read the FAQ!
