Line Driver Selection? And Audio advice
  • Line Driver Selection? And Audio advice
    Trying to Setup my system and I want a line driver to boost my signal and hopefully help with unwanted noise. Been reading alot on the Forum and decidied to use it fron the Start, But I dont know which Line driver to Get. My Sound system will be my EPia M1000, Audigy 2 ZS Soundcard, Two Infinity amps ( 111X4rms @ 4ohms & 400-500rms @ 4 ohms) 1 Farad Capacitor, And some type of Line Driver. Can you guys help me choose, and if you can think of any part of my system that my need some help please do reccommend. Trying to spend $50-$10 on th Line driver. Would prefer used. Thanks fellas
    My personal choice for several reasons (including subwoofer control, 7v max output, dual inputs, etc) is the Memphis EQP4.
      there's this little known company called audiocontrol that makes these little line drivers and crossovers that keep winning all these little "_____ of the year" awards. I'd check THOSE out.
      Carputer Progress: Here we go again...
      THE GF THEME
      Genesis has speed
      Genesis has class
      Genesis sent money
      before your a__;)
      Join the fight against carputters. EMAIL ME!
        Can someone give me specific model numbers? Do I need one with two seperate Inputs and outputs to control the two different amps. Here are Links to three I were considering
        http://cgi.ebay.com/PHOENIX-GOLD-SLD...QQcmdZViewItem
        http://cgi.ebay.com/Kove-KA-6-Line-D...QQcmdZViewItem
        http://cgi.ebay.com/AUDIOCONTROL-MAT...QQcmdZViewItem
        Any Help is grateful
          considering you'd be using 5 channels. you'd probably want to look at the audiocontrol 6xs front rear and sub and a separate channel if you ever plan to go 5.1
          Sell me your stuff.. please see what i'm looking to buy
          http://mp3car.com/vbulletin/showthread.php?t=75182
            Audiocontrol is awesome. It's a little expensive, but:
            http://www.techronics.com/index.cfm?...roduct_ID=2132
              I have an audiocontrol line driver in my system, and it is a great little unit. Worth the money.
