Digital Audio drop out???
  • Digital Audio drop out???
    I have converted to digital audio using the X-Fi from SB and the Autotek 5.1 amp.
    Lately I have heard a half second audio drop put once or twice per song. I originally thought it may be a loose connection but it happens while standing still. I have yet to time them but they seem even intervals. This needs to be troubleshot, but Im not sure how...
    How can i determine whether the amplifier's D/A convertor is the cause or if its the computer (source)? This did not happen using analog connections
    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
    did you make sure your drivers are up to date? i had a similar problem with onboard spdif out and the drivers fixed most of my issues
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      I had thought I had the most recent. I will check again to make sure
