HU mounting question.
  • HU mounting question.
    Hey guys i'm not 100% sure on this one thing, I'm making a custom lower console in my 2004 toyota matrix to relocate my HU to. I know that pioneer says that it's safe to mount their HU's at 45 degrees. What if I mount it any higher than that? I'm not going to 90 degrees, but I ned to increase the angle because I'm running into clearance issues between the ebrake and the lower shifter panel. If this is just for the CD player part of the HU, and nothing else will be affected, then thats fine with me, I'm going to primarily be using the HU only for volume control and as my EQ, Everything else will be run from the PC.
    Yes, angle should only affect CD playability.
      any pics of this process?
      and I'll just second what Jahntassa said
      Jan Bennett
        Only effect the CD player.
        Go for it.
