Low-budget SPL Subs
  • Low-budget SPL Subs
    Cliff Notes: SPL sub(s) for ~250-300 dollars?
    Two popular choices seem to be Alpine Type Rs and Kicker L7s. I have 2.2 cubic feet to work with. I have nothing wrong against either of the two above companies, but I wanted to see what others have to say. I've mainly focused on SQ setups with all my research and personally. Right now I have two JL 10W3s in the car in a sealed box with each sub having 0.9 cubic feet of space. I wanna replace this with something that'll blur my vision. I have a amp lined up, but I'm undecided on the sub(s). I was thinking of going with either those two up there, or maybe a single Soundsplinter rl-p or IDMAX. I heard good things about Digital Designs but they don't have any prices on their site. I e-mailed them about it, waiting on their reply. I also tried contacting RE Audio but they never got back to me so they're out. Suggestions on sub(s) for up to 300 dollars? I'm only going to be playing with about 900-1100wrms to power the sub(s) because I don't have the electrical system to support any more than that.
    wow...2.2 cf in a miata? i'm impressed. I was going to suggest looking into teh soundsplinter and idmax...so i have nothing useful to add. :-)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      ?? No, I don't drive a Miata. I doubt that car has that much space to work with. I drive a Millenia
      http://i4.photobucket.com/albums/y14...a/IMG_0015.jpg
      http://i4.photobucket.com/albums/y14...a/DSCN0453.jpg
        The rl-p and idmax are both known more as SQL subs not as SPL so thats why Im not really looking at those two that much....plus the IDMAX v4 is supposed to come out this year.
          sorry, my bad. read miata not mazda.
          anyways, 3ondubs has two idmax 12's in his bmw and i think the bass scares him :-)
          M10k
          My Car Pc Install
          My Boat Pc worklog
            In your header it says SPL and in your message it says "I've mainly focused on SQ"...
            Check out the Pioneer/Premiere lines if you want cheap/quality/loud in one package.
            http://www.pioneerelectronics.com/pn...etailComponent
            That's a 12 with 1000 RMS power handling, they have a 10 with 800 RMS power handling as well.
            homebrew sound deadening + sub and amp install... 04 Dakota QC
            fuel economy calculators
              i think he means in the past he's only focused on sq, so spl is new to him and that's why he's asking for help.
              M10k
              My Car Pc Install
              My Boat Pc worklog
                yea exactly
                  I'd find some prices on the DD subs then. they can pound, no doubt. Not sure how expensive (or inexpensive) they are though. A single 12 with 2.2 cu. ft. should be plenty, port it on top of that, and you should have some good output.
                  Jan Bennett
                    The optimal setup for one 12" IDMAX is a 2.2 cu. ft. (after displacement) ported box.
                    PostCount++
                    - SrCsTc's Bezel
                    - Alpine W200/H701
                    - ED Nine.2X
                    - OZ Matrix Elites
                    - ED Nine.1
                    - Idmax 12's
                      Hey, what do you guys think of these specs? I wish the sensitivity was a bit higher, although thats not even that bad.
                      Thiele Small parameters:
                      Fs (Hz) 24.85
                      Qms 6.456
                      Qes .486
                      Qts .452
                      VAS (ltrs) 48.44
                      Zn (ohm) 4
                      Re (ohm) 2.79
                      Le (mH) 3
                      Rms (Kg/s)
                      Mms (g) 286.6
                      Cms (mm/N) .143
                      Bl (N/A) 16.04
                      Sd (cm&#178 488.4
                      2.83V SPL (dB) 88.42
                      Pe Cont (W) 500
                      Xmax (mm) 23
                      VC diam (mm)
                      2"
                      VC length (mm) 2.1"
                      Gap height (mm) .385"
                        i can get u 2..13.5 jl audio w6s for 650 plus shpping
                        i got dat ***** sittin on 22s! SUPERMAN EDITION!
                          Good price but I don't have that much to spend. What other brands do you carry? Are you a dealer or..?
                            no i get these from a buddy...
