Automatic Eq change?
  • Automatic Eq change?
    Anyone know a player/software/pluging that not only saves a customed EQ setting for a some, but also changes the EQ to a predetermined on as it changes genre? I mean, its kinda sucky to have the heavy bass of Swtich Remix of WIll SMith and Elephant Man followed by an acapella version of Beauitufl Dya by U2...kinda needs a new EQ setting. Hate to have to do that for every song. NAy ideas?
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    no no, not the car's EQ, the computer's EQ. Car EQ is to be set to flatten the car, the computer EQ is what i need adjusted per song. Sometimes i just want more bass in some songs than others. Sometimes i want the highs accented.
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
      You can easily do that in Road Runner, I believe auto load EQ presets is listed in skincommands.txt. I did it myself for quite some time, although now I'm using a VST EQ plugin. I know exactly what you mean about needing to adjust bass between certain albums. Right now I'm back to using the bass and treble controls on my DSP, which are too broad in their effect. But it's worth the inconvenience for kernel streaming.
      In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
        i mean like, you have rip hip hop genra, its gets a specific eq setting. THen orchestral/vocal, it gets an eq setting then, then rock, then techno...
        And then if there are song specifi eq's, they have a preset setting. Basically, by defaut, all songs have a base EQ setting based on genre and then if i want to tweak the songs a bit more, they get the tweaked settings.
        THE GF THEME
        Genesis has speed
        Genesis has class
        Genesis sent money
        before your a__;)
          You can have a custom preset for every single song if you want, that will load when the song loads, and songs you don't have custom presets for will use whatever standard preset you have your EQ on by default.
          http://www.mp3car.com/vbulletin/show...ght=EQ+presets
            Thanks. Looked into it. I kinda wish it worked as a seperate peice fo software. Although, since it may be a winamp plugin....
            THE GF THEME
            Genesis has speed
            Genesis has class
            Genesis sent money
            before your a__;)
