Equalizers
  • Equalizers
    I just got the carPC in the car and I don't know what to do about fade and subwoofer controls..with the HU I was able to fade to the fronts and manage subwoofer output and everything else...what are you guys using to do this now if your running HUless? I have the Chaintech AV-710. I searched but came up with nothing conclusive except to buy an equalizer.
    I have an Alpine ERA-G320.
    It's an equalizer.
      you should have some options on your sound card software. Are you running any aftermarket amps or anything?
      Jan Bennett
        The driver cd I got with the AV-710 came with no software just the drivers
          ok - what about your amps? are you running any?
          Jan Bennett
            Yea, 2ch for the subs and a 4 ch for the front components and rear coax's
              have you ever tuned your system?
              tuned correctly and you won't need to mess with the fade, etc ever
              Jan Bennett
