HUs with detachable face for remote mounting
  • HUs with detachable face for remote mounting
    For those of you who have successfully been able to remote mount your detachable face head units, can you list them here in this thread and also mention any issues or concerns that you ran into?
    I think this would be a good resource to those looking to do the same thing.
    Jan Bennett
    Pioneer DEH-P6400
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
      Today I bought a brand new Alpine CDA-9856.
      I tried the remote mounting it worked great. Everything functioned correctly. I used 3 ft cat6 cable soldered at each end and then used a connector to connect them together. Took about 2 hours. I was talking to one of the guys at the stereo shop and they told me that this should work on ALL alpines. I think the people who had trouble doing it weren't connecting it correctly. I will be doing another one soon on a new pioneer so i'll post my results when im done.
        Congratulations on your project! I'm glad it worked for you!
        I'd say it worked for you because of the 3 foot cable. I doubt that would be long enough for most people if they want to mount the faceplate on their sunvisor. My cable was closer to 10 feet. Its the low power and the cable distance that make it so that it doesn't work with most head units.
        8" Lilli TS
        MB896F Mini-ITX MB
        1GB SDRAM DDR2 533
        3COM BKP Cam
          im not so sure i buy the long cable theory. cable resistance should only matter if the faceplate was drawing high current. The dude at the stereo shop said he did it in a lot of boats and the cables were over 20 feet long. But who knows. I think the most important thing is how well your soldering job is and how well you can secure the cable so it doesnt come off. i'll post some pics when im done with my whole project.
            cat 5 over long distances and other wire over long distances are different stories.
            Jan Bennett
              Even if it was a power thing, couldn't you just wire up some simple transistors to a power supply, and then use that to boost it? They should be ample fast for data streams as well? Could a simple solution work?
              1.9in x 2.9in -- 47mm x 73mm
                there really shouldn't be any current on a face plate. Everything on a face plate is very low current, leds and switch points, etc.
                The biggest issue is the solder joint, since Cat 5 is solid, making the connection will be difficult.
                But, it can be done!
                Jan Bennett
                  yeah, i did my soldering on an expensive metcal soldering workstation from my work. I used the thinnest tip to do it. Tint the gold connectors first, tint the ends of the wires, and then just touch them and solder, very easy. But if you using one of those big tipped radio shack soldering irons, then the job is definitely more challenging.
                    anybody have pictures? i want to see this
                    screen name here use to be MegaloRESE15"
                      Still working on my car right now, but heres a preview on what the detachable hu looks like.
                        hi guys,
                        I have a Pioneer P6400R and would like to have this done, but i cannot solder.
                        I live in the UK in Norfolk, does anyone live nearby or can anyone offer any help. I already had a go and it took me 5 hours to remove the solder. The head unit is working again now, but needs soldering cat5 cables. i have the cables and coupler too.
                        07979 42 46 27 - Drew
                        Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
                        http://www.digital-car.co.uk
                          soldering isnt that difficult really, as long as you have a good thin tip, and make sure not to keep the soldering iron on the surface for too long you should be fine (and yes, tinning both sides helps a LOT) touch both together, then touch with the soldering iron, remove soldering iron
                          done!
                          dunno why a lot of people have problems with it, its not that hard :T
                            soldering is cake, it's no excuse to say you don't know how to solder....give it a try at least!!!
                            Jan Bennett
                              Hey Guys,
                              I did give it a try and a managed to screw it up and it took ages to reclean all of the solder so the screen would work again.
                              Just looking for someone to help that was all.
                              I'll keep looking.
