How To Remove A Ford 4500 radio?
  • How To Remove A Ford 4500 radio?
    Hi there,
    I need to remove my 4500 radio from my ford fiesta can any1 tell me how to remove it coz it seems to be in 3 parts. But i have found a pic of it on e-bay and it is just 1 radio. But seems to have 2 bars across it.
    Thanks for any help.
    You realy should take this to either a dedicated forum for car stereos or a Ford-specific forum for a quicker response.
      Some of the Ford radios are a pain to remove. No obvious screws or connectors.
      This may help:
        That's like the Focus in the US?
        OWNED. That sucks.
        try here
          looks almost like youd have to pull the dash apart to get to it
          great antitheft huh?
          1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
          Photobucket is being updated, if a picture i posted no longer works, please PM me.
            Eh, it's a Ford and it probably pops right apart and the radio's probably held in by 3-4 7mm screws.
              you have to remove the main center panel, remove the 4 switched to the left and there are 2 screws, open glove box and are 1 or 2 there, 2 to bottom of panel going upwards( need stubby screwdriver) remove lower dash on drivers side,( 3 screws alone bottom, 2 inside cubby hole amd then clip in corner)this allows access to screws on side of the panel, then look for heater cables connection on right side of heater box( may need to remover panel to get good access, its only 2 screws) then the whole panel lifts off. radio is held in by 4 screws, and then it just pulls out.....
              sounds complicated but if you look and take your time its simple enough, takes about 10 mins!
