Powering Sound Blaster USB Sound Card
  • Powering Sound Blaster USB Sound Card
    I have a usb sound card from creative labs what takes a exturnal 5v power. Is there any reason i can't power it from the 5v rail of the carpc PS?
    -William
    FKA psptibby
    are u using yellow or the red from the ps?
      It would be the red correct? Since that is tghe 5v rail?
      FKA psptibby
        Yes, red is the +5v.
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          So that should work right?
          How do you find out how much load is on the opus power supply? I have a 90w one.
          FKA psptibby
            Yes. That's how most people power their LCD screens, except they use the yellow wire (+12v).
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              Cool, now would it be safe to have 2 unpowered usb hubs linked together or is that not a good idea for the PS.
              FKA psptibby
                You'll have problems with the devices you plug into those unpowered hubs. Powered hubs are the way to go.
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  Okay, could i wire the powered hubs to the 5v rail or is the too much of a load on the PS?
                  FKA psptibby
                    Shouldn't be too much load unless you're overloading the PSU else where.
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      I have gps and the touchscreen, hard drive. And then the cdrom will be attached usb. Then i am adding a usb card, oh and bluetooth. The 2nd hub will be for user port availble to driver or passenger in the car as well as a memory card reader.
                      Do you think that is too much? Most of the is low powered devices.
                      FKA psptibby
                        What motherboard/cpu and what power supply are you using?
                        And hey... if the PSU can't supply enough, you can always get a opus point of load psu just for that line.
                        GammaControl v2.4
                        SKINbedder v3
                        1995 Lexus SC300
                          its the via 1.2ghz board witht the m1-atx 90w ps.
                          What is the opus piont of load?
                          FKA psptibby
                            check this:
                            http://www.opussolutions.com/index.php?p=product&id=24
                            Prepping for Trax in september
                            Re-Building the whole CarPC to upgrade all the software
                            Whole new boot build and moulding my screen into the dash...Again
                              Interesting. So that is a serperate psu for devices? That would be wired to the battery?
                              FKA psptibby
